X-Monitor Trans Temp
Old Jan 14, 2005 | 11:45 PM
durasmack's Avatar
Question X-Monitor Trans Temp
I was able to obtain a BD X-Monitor for a greatly discounted price that was designed for an F-series truck. I assume there will be no problem using the boost gauge or pyro as those probes seem to be fairly universal. I was curious as to whether or not the trans temp gauge would work on a dodge transmission and what would the best way to install a trans temp gauge be?
Old Jan 15, 2005 | 12:26 AM
infidel's Avatar
It should work just fine. Best way to install the tranny temp sender is to buy an output line to the cooler for '95 that has a port in it for the sender, about $100.
If I'm not mistaken it's Dodge p/n CH05011244AA
Old Jan 15, 2005 | 07:45 PM
durasmack's Avatar
now to get inventive with a way to mount it..... it has a ford pillar!!! i think i will make an aluminum insert to replace the ashtray and wire it up in there...... havent come up with a better location yet..... any thoughts on how that will look?
--Trey
Old Jan 15, 2005 | 10:18 PM
greenworks's Avatar
The ashtray is a great spot to mount things, i have my comp box and high idle switch mounted in there gives teh truck a stock look until rqace time
Old Jan 15, 2005 | 10:54 PM
durasmack's Avatar
i was going to remove the ashtray and put the gauges on the face, i think it will look good...... as for stuff to be raced around here...... many of them can be stomped with a stock truck...... not sure why or how, but ive tried it.
Richpwb
Aug 15, 2008 08:01 PM
mowin4dodge
Mar 17, 2008 10:08 AM
nitis
Feb 26, 2007 07:38 PM
Smokeman
13
Sep 12, 2006 03:59 PM
RamRat
Apr 3, 2004 12:53 PM
