Quadzila gauges instillation question
Im looking at the simplest way to get some gauges specifically a fuel pressure gauge. This quadzila system seems to be a good way to go besides the fact that I have to buy a separate fuel pressure unit. However I am curious if it comes with all the other sensors to, egt, boost, tran temp oil etc. Or does it just plug into the trucks computer. The simple question were does quadzila gather the info?
Id be interested to hear about other gauge set up to. But I don’t want to install a chip because the rig is under warranty.
Thanks
Thanks
Thanks
Thanks
BTW if you use the commander they will think you have chip anyway, just b/c of the computer display. so do analog gauges and a smarty(its undectecable)
good luck
Alright that makes sense about them thinking its chipped. Where is a good spot to start looking at gauges and what kind would you recomend? Additionally what three do you think would be the best to run. fuel, egt, and _____? Is there a way to mount easily more then three and were all can you mount them besides on a pillar type set up? Thanks
Boost, Egt, FP, are the 3 main's I don't have a piller mount cause it already had boost and egt mounted on the dash. I am mounting a fuel pressure this weekend but it is going to go in the cubby hole next to the radio. GENO's GARAGE has a piece to mount a single gage in this useless hole for$7.50
if you do a search on here for cheap gauges or cheapest and youll find some a little cheaper. fuel, egt, boost.
mowin4dodge
Dec 18, 2010 10:43 PM
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
AggiePhil
Jan 30, 2005 01:15 PM
