PYRO wire length for pod
Old Jun 23, 2004 | 01:07 PM
360ramcharger's Avatar
I got a 3 gauge pod for my truck, is the pyro wire long enough to reach the pod? I had to buy longer tubing for the Boost gauge.
it will be plumbed before the turbo. "I was told the boost gauge tube was more than long enough".
Thanks Ya'll
Old Jun 23, 2004 | 01:13 PM
Mike D's Avatar
I guess it depends on what guage you bought... I have an Isspro and it was plenty long.
Old Jun 23, 2004 | 01:47 PM
Pyro wire
forgot to add that, its an autometer 8ft length got it from Geno's
Old Jun 23, 2004 | 02:14 PM
DaNuGuy's Avatar
I haven't done mine yet, but it sure looks long enough. It actually states in the directions(yes I read them and am PROUD to admit it) that the lenght of the wire is part of the gauge calibration. I have autometer also. Where did you plumb your boost into? Mine was plenty long, I went into the intake right behind the fuel filter. Maybe they are different 12v to 24v. I'm going to wire my pyro tonight so we'll see if it is long enough.
Old Jun 23, 2004 | 02:20 PM
USCGtraveler's Avatar
I installed an AutoMeter Pyro that has a Probe lead that goes to the Pyro module that mounts under the dash and then the wires from the gauge go to the module. I had plenty left over to coil and bundle
Old Jun 23, 2004 | 02:33 PM
MLR1's Avatar
I have installed 4 or 5 Auto meeter pyros and the wire is long enough for pre or post, with the guage in the center hole.
Old Jun 23, 2004 | 07:38 PM
DaNuGuy's Avatar
I ran all the wiring for the pyro tonight and it will reach, no problem.
Old Jun 23, 2004 | 08:15 PM
amartinson's Avatar
The pyro wires are plenty long. You are correct on the boost gauge though, mine barely made it and now I will be adding a FP gauge and moving the boost gauge farther up the pillar. I hope it makes it.
Where did you get a longer tube?
Old Jun 24, 2004 | 09:12 AM
thanks for all the input, I will have my gauges on friday. just worried about spending that much money and have to reengineer the thing so it works.
Ive only had this truck for two weeks so im still learning the Diesel way.
thanks all.
Old Jun 24, 2004 | 09:56 AM
infidel's Avatar
Most any auto parts has it for less than 20¢ a foot. It's used for oil pressure gauges and some smog control systems.
Old Jun 24, 2004 | 12:06 PM
I ordered it from a local speed shop "virginiaspeed.com" $11.00 for 12ft its an AutoMeter item you should be able to find it at jegs/summit. I couldnt find anyone here who had it by the foot.
Old Sep 13, 2005 | 08:08 PM
Dave88LX's Avatar
Those of you that went with the Autometer pyro's:
Was the wire leads coming off the pyro staggered, as in one was about an inch or so longer than the other?
How about the wiring going from the probe to the gauge? Were those even? Or was one end staggered?
I have my pyro staggered, but the wire going to the gauge is cut even, instead of staggered as well, so it's going to make an ugly loop/bend in the wiring...
Old Sep 13, 2005 | 08:22 PM
phox_mulder's Avatar
I think they do that to compensate for slightly different readings from the probe.
No two probes are identical, so they stagger the wires to make the readings the same at the ends of the wires.
All instructions I've seen say do NOT cut the wires coming off the probe.
If the pyro has a seperate amp box, then the wires between that and the guage you can shorten to fit.
phox
BrokeSolid
21
Feb 3, 2009 09:36 AM
scarecrow
Mar 9, 2006 08:12 PM
royta
27
Mar 22, 2005 03:01 PM
SilverDiesel
Jan 1, 2004 03:14 AM
TPilaske
16
Nov 22, 2002 08:15 PM
