put in the 0 plate
Old Apr 11, 2007 | 08:57 PM
Brendan's Avatar
put in the 0 plate
Well I put in a custom zero, I call it this because we tappered (ever so slightly) a curve on the bottom end fueling to provide some driveability. It is truly something else, it will now hit 1500 degrees on the pyro within a few seconds . It pulls super strong in every gear which is the biggest difference, before it would top out in OD at 20 psi . Just thought I'd keep yall informed!
Old Apr 11, 2007 | 09:26 PM
dodgediesel's Avatar
Where did you purchase the 0 plate?
Old Apr 11, 2007 | 09:41 PM
Tate's Avatar
He ground it out of a different plate, probably the stocker.
Old Apr 11, 2007 | 11:14 PM
Brendan's Avatar
Ya I ground it from the stock plate, Now I have this #8 plate to get rid of...
Old Apr 12, 2007 | 10:00 AM
Lil Dog's Avatar
#0 plates are awesome if you can handle the air for it up high in the RPM range.
Old Apr 12, 2007 | 11:53 AM
schoust's Avatar
Hmm I have been thinking this would be nice in my truck but 1500 in secounds that sounds like a melt down in the process with the stock turbo...........
Old Apr 12, 2007 | 12:24 PM
Lil Dog's Avatar
Ya, not much fun to have all the fuel and not be able to use it...
Old Apr 12, 2007 | 12:55 PM
Mav's Avatar
Mav
Getcha a aurora 5000
Old Apr 12, 2007 | 07:27 PM
cumminsdriver635's Avatar
Advance your timing! Mine would peg the gauge from 0-70mph before I got it timed, and that was with 131 delivery valves, and the 160 injectors. Now that I got it timed I am hard pressed to get it over 1300*. Also, a tighter torque converter will help with EGT's because it keeps you out of the higher rpm's. If you have a fairly loose converter that never pulls you below say 2700rpm's then you will really have a hard time keeping it cool, cause that is where these 12 valves get hot is up high. I definately like my 0 though
Eric
Old Apr 12, 2007 | 07:34 PM
mysterystench's Avatar
Brendan, how much for the #8?
Old Apr 12, 2007 | 09:24 PM
Brendan's Avatar
What are they worth new? You can have it for 60% of that cost. PM me if you want it.
On another note, if you spike at 1300 on the pyro for a few seconds, is damage impending? or do you need to go up to the 14s and 15s? I'm thinking water meth might be a good idea at this point.
Old Apr 13, 2007 | 04:17 AM
1300* for a few seconds is fine. My cousin who's truck we have apart right now had seen 1600* many times for 5-10 seconds, and the engine looks like a new one. You can get them really hot as long as you dont hold it there...
Eric
Old Apr 13, 2007 | 07:18 AM
ckt_santiago's Avatar
Take cumminsdriver's advice on the timing. Water meth is quite a hassle with a stock HG on a 12v and no studs...
barngal6
Jul 5, 2009 06:49 PM
gs1000
14
May 4, 2006 12:02 PM
chadpatten
Nov 26, 2005 12:32 AM
banks twinram
Feb 5, 2005 10:38 AM
