Proven 500+hp combos for H.O.'s ??????
Old Feb 13, 2006 | 11:02 PM
  #61
Don M's Avatar
DTR Advertiser
Originally Posted by BigBlue
My roommate finally got on a dyno and laid down 402hp. Dyno wasn't picking up torque that night. For what it's worth, we did a dyno on both his truck and mine with a standard and then a drag comp and peak power was the same on both trucks but there was an additional 40hp after 2700rpm on both trucks.
Tyler, what turbo did he get? 402 is pretty good for Mach 1.5's and a COMP on yukky winter fuel.
Old Feb 13, 2006 | 11:13 PM
  #62
Don M's Avatar
DTR Advertiser
Originally Posted by CTD_Neil
Ok, looking at my sig, what do I NEED to make 500+ hp? I'm guessing my turbo will need to be upgraded to a 64/14 right? What injectors? anything else? Thanks
Its not the 62 part of the 62/12 that might hurt the 500 HP mark. Its the 12. The housing is somewhat tight/restrictive. HTT might be able to get you a 14 housing for the turbo you have and save you money.
You have some choices on fuel:
1) The HRVP44 with the injectors you have should do 500 or real close.
2) M4.5's and keep the pump you have will make 500. Ultra driveable!
3) M4 or 4.5 and the HRVP44 and you will make 565-580. No Joke. I had a customer make 604HP with a HRVP44 and M4's. He had a PS66 turbo.
If you want to keep the turbo you have, the HRVP44 with M5's will crack 530 with ease, but will run hot on high box settings.
Old Feb 13, 2006 | 11:35 PM
  #63
BigBlue's Avatar
That was with a Super B. He's got an 01 HO with a drag comp, Mach 1.5's, Super B Turbo, Scotty 2, 4" straight pipe. This was on summer fuel back in say september or so. I was dang impressed with those numbers. He did I think two runs at 401 and one at 402. Needless to say, my 371 with a comp and 275's and a ksb-1 felt pretty inadequate at that point which prompted me to buy 100+hp injectors and now a catcher. When does it end?
Old Feb 13, 2006 | 11:44 PM
  #64
Don M's Avatar
DTR Advertiser
It has not ended for me yet
Old Feb 13, 2006 | 11:46 PM
  #65
BigBlue's Avatar
I ain't even close. In fact, about 250-300hp off of my goal. If only I could get the tranny built this summer I'd be golden. We shall see.
Old Feb 14, 2006 | 01:54 AM
  #66
95ram's Avatar
How bout I say they'll be in the 2's and leave it at that.
Old Feb 14, 2006 | 07:31 AM
  #67
getblown5.9's Avatar
well i have a adkins lil 55 headed my way very soon, and my comp will be getting upgraded to a drag version by the end of the month.
im also preparing to swap out my injectors for some 150hp units so i should be just shy of 500hp by the time the spring dyno day rolls around for the MDTDC...gonna be a fun day for sure.
Old Mar 4, 2006 | 11:28 PM
  #68
CTD_Neil's Avatar
Read through this one again and noticed a few of you were waiting to dyno again, anybody have recent dyno results? Looks like i'll be going with injectors from DonM in the Mach 4.5-4.9 range. I still need to talk to him about it though. I would like to crack 500hp without getting a HRVP44. Dyno days are coming up around here, gotta get movin! I need to find 66 horsepower to get there!
Old Mar 5, 2006 | 04:01 PM
  #69
MSquare's Avatar
I still haven't made it back to re-dyno (?). Just been busy with other projects and when my time was open, the dyno wasn't.....figures. I will post as soon as I can get it done.
Old Mar 5, 2006 | 04:52 PM
  #70
Ph4tty's Avatar
I should have my clutch on in a week or two then I'll be ready to play.
Old Nov 15, 2006 | 05:44 PM
  #71
CTD_Neil's Avatar
Back to the top
Old Nov 15, 2006 | 05:48 PM
  #72
blackdiesel's Avatar
Registered
need to get on the dyno asap! but im well over 500 hp......
Old Nov 15, 2006 | 10:39 PM
  #73
Ph4tty's Avatar
I need to dyno too
Old Nov 16, 2006 | 07:01 AM
  #74
i wanna dyno on a mustang dyno...just for the fact that they can load the engine and i might be able to get a higher tq reading...just for bragging rights!
Old Nov 16, 2006 | 07:08 AM
  #75
99blackrig's Avatar
I just dynoed the other day on a mustang dyno. How much are they supposed to load the dyno. They loaded it with me around 28%, which wouldn't allow me to pull very high rpms.
