propane
Old Jul 9, 2006 | 03:35 PM
blackdiesel's Avatar
Registered
propane
how useful is propane? i dont really care about the mpg increase, im just wondering how it performs. any good setups? any advice? good or bad, all is welcome! Thanks alot
Old Jul 9, 2006 | 03:38 PM
Austin'sDodge's Avatar
It runs hotter, but with the twins you would probably be fine. Might look into water/meth or even nitrous. They both have a cooling effect.
Old Jul 9, 2006 | 03:42 PM
Registered
i was looking at the water/meth too.
Old Jul 9, 2006 | 04:01 PM
Bart Timothy's Avatar
Depending upon the amount of diesel fueling, propane will do a good job increasing power. The heavirer diesel fueling you run the less effect propane is. It's hard on head gaskets so it's a good idea to keep power increases, it does produce, under 100, maybe no higher than 70 or 80, even less than that if your timing is advanced (i.e. EZ, VA, and Comp boxes).
It does burn cooler than diesel, by itself, but because it is actually adding extra fuel to the overall mix and therefore really doesn't decrease egts.
The biggest hastle I've in running propane over the past 6 years is in getting the tank filled. Doubles or triples fuel stop times.
Old Jul 9, 2006 | 04:06 PM
Registered
well filling it up is no problem. im gunna rig up a way to fill it up out of the propane tank outside
so if im running lets say- a tst pm3, smarty, 130 hp injectors, water/meth - will propane give me enough of a boost to be worth it?
Old Jul 9, 2006 | 04:28 PM
It will a power and milage boost to that combination, but whether it's worth it, or not, is your call.
Old Jul 9, 2006 | 04:40 PM
Registered
humm.... oh who am i kidding, of course its worth it!
Old Aug 8, 2006 | 06:00 AM
Ironstone's Avatar
I have read on another forum that propane will decarbonise (if thats a word) the cylinders. Anyone else know anything about this.
Old Aug 10, 2006 | 08:33 PM
24Vford's Avatar
i have a powershot 2000 kit and ran it on my powerstrokes it was the best bang for my buck but have not yet put it on my cummins
Flatbed24v
Jul 31, 2009 10:57 AM
PowerDually
Jun 12, 2005 10:51 AM
Nov 4, 2002 10:52 AM
CMN_NOT_STROKN
21
Oct 5, 2002 02:12 PM
