Problems with 370's
Old Feb 13, 2007 | 12:02 PM
toyota31's Avatar
Problems with 370's
OK i got the 370 in my truck and took it out for a drive today and when i brought it back and the injectors are leaking where they go into the head. Took them out cleaned everything again and put them back in and same thing. So what is going on? Has anyone else had this trouble when they put 370's in? What should i try to get it to stop leaking? Help me out guys ive been without my truck for 4 weeks and i want it back on the road. Thanks.
Old Feb 13, 2007 | 12:04 PM
signature600's Avatar
Did you put new washers on everywhere?? Bottom of injectors, return lines? What did you torque the hold down nuts to?
Chris
Old Feb 13, 2007 | 12:07 PM
toyota31's Avatar
yes new washers everywhere and torqued down.
Could there be too thick of a copper washer on the nozzle?
Old Feb 13, 2007 | 12:37 PM
Too thick shouldn't cause that...to thin could, if the injector bottomed out and didn't seal! Did you clean the injector bores with a wire brush?
Chris
Old Feb 13, 2007 | 12:42 PM
toyota31's Avatar
I cleaned the bores twice just to make sure it was clean. Im gona try a different set of washers and see if that helps.
Old Feb 13, 2007 | 12:44 PM
Sounds like a plan...I'm sure someone else will chime in with more ideas later, but it sounds like you did everything correctly!
Chris
Old Feb 13, 2007 | 01:12 PM
Mcmopar's Avatar
Arn't you supposed to use the thin washers with the 370's?
Old Feb 13, 2007 | 01:33 PM
berner's Avatar
I had to take my return line off and clean it up with emory paper to get it to stop leaking when I installed my 215's. Different injectors didn't help. Maybe you're leaking at the return line connections.
DJ Turbo.
Oct 13, 2011 09:11 PM
dodgeman01
13
Apr 15, 2003 08:04 AM
BGDUMMY
Jan 6, 2003 03:08 PM
R-O-B
15
Oct 31, 2002 11:49 PM
