problem shifting 98 24 valve
Old Aug 20, 2008 | 11:36 AM
landscaper3's Avatar
I spent some time and came up with the truck doesnt miss at top end it stays in each gear wayyyy to long and stays at the 3000+ rev limiter forever and thats why the truck cuts out or misses, beside purchasing a really good trany what could be done to shift much earlier in 3rd-4th and 5th! any ideas??????
Old Aug 20, 2008 | 12:15 PM
dzlfarmboy's Avatar
There's a TV cable adjustment under the a black plastic cover to the right of your valve cover that might be need of adjustment. And your 47RE is just a 4 speed trans with lockup.
Old Aug 20, 2008 | 03:01 PM
Is it on the drivers side or passenger side
Old Aug 20, 2008 | 03:24 PM
I had the trany checked it has 150lbs pressure wide open and through a code #p1765 but I have a lock up switch installed and took relay out and installed jumper wire,.. And its a stock trany too
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
fourwhls00
Aug 4, 2004 10:04 PM
Cumminsdude
Aug 13, 2003 12:50 PM
warden
Feb 23, 2003 10:20 AM
