Shifting Problem??
Old Aug 4, 2003 | 07:41 PM
Cumminsdude's Avatar
Shifting Problem??
Ok guys, my truck shifts funny now. Whenever I am around 39 mph and 1200 rpm's it keeps going in and out of over drive? Whats going on here? Should I try resetting the APPS? If so what could go wrong if I did that, because I have the Fecal touch! Everything I touch turns to crap!
Oh BTW I just saw two either 03's or 04's 3500 and wow are they nice. I WANT ONE!
Old Aug 4, 2003 | 07:44 PM
Dr. Evil's Avatar
Re:Shifting Problem??
I would think it would shift funny at 12 000 rpm.... ;D
Old Aug 4, 2003 | 07:48 PM
Well I just checked the tranny fluid in Neutral because I read on the other page your supposed to do that and its down a little bit, just below the bends in the metal. So I am going to get some fluid and put that in and I will post back tomorrow. Thanks
BTW, its never done this before thats why I am wondering.
Old Aug 4, 2003 | 07:57 PM
Dr. Evil's Avatar
Make sure u use the right flavor of ATF.
Old Aug 4, 2003 | 08:05 PM
drecu's Avatar
If the Fluid & the ARRS Recal don't fix it you need TSB 18-02-99 it's a reflash from dadge cost about 60 bucks.
DRecu!
Old Aug 4, 2003 | 10:05 PM
Dr. Evil's Avatar
Yeah Id be kinda worried if my tach said 12 000 !
Old Aug 5, 2003 | 09:56 AM
oops my bad. ok I put some fluid in it and it stopped doing that or at least I cant tell but it seems whenever I press the gas and its under a little load then let off imediately it jumps out of OD and revs up a little. Does anyone know what I am talking about?
Old Aug 6, 2003 | 11:53 AM
drecu's Avatar
Yep it's going in & out of lockup check that TSB in my last post in this thread.
DRecu!
Old Aug 6, 2003 | 12:22 PM
[quote author=drecu link=board=13;threadid=17972;start=0#msg168979 date=1060188838]
DRecu!
[/quote]
That will fix it huh? Alright, but I have to go to the dealer to do it right? Thanks a lot I really appreciate it.
Old Aug 6, 2003 | 12:26 PM
drecu's Avatar
Yeah I had the same problem with my 99 let me get the link.
http://dodgeram.info/tsb/1999/18-02-99.htm worked on my truck beautiful check & make sure your battery terminals are clean also first
DRecu!
Old Aug 6, 2003 | 01:45 PM
ok, what should I say to the dealership so I dont sound like an idiot! I mean I just dont want to walk in there and say I need this and so and so and then they are like well whats that and I am like uhh I dont know but I need it, u know. Should it take longer than half and hour?
Old Aug 6, 2003 | 02:05 PM
Bearfoot2's Avatar
Make a copy of the TSB and take it with you. Explain to them how the truck is acting, show them it is the same symptoms as explained in the TSB.
Should take approx. 1/2 hour.
Old Aug 8, 2003 | 12:11 PM
Well I called and have and appointment for Wednesday at 10 so hopefully this will fix it. He said they charge $50 and hour and however long it will take so lets hope it really only takes half and hour, but u know these guys they will stretch it! Also the guy was real curious as to who gave me the TSB number! I told him my friends from the internet! Thanks for all the help, I'll let you know if this is what it is. They are also going to check my fuel pressure while I am there so I can see if my lift pump is bad or going! Thanks again guys.
Old Aug 8, 2003 | 12:27 PM
Bearfoot2's Avatar
[quote author=Cumminsdude link=board=13;threadid=17972;start=0#msg170021 date=1060362677]
Thanks again guys.[/quote]
Hey ...Dude, No prob. That is the primary purpose of the forum and why we all 'hang out' here.
Stan
