Possible cheap high idle
Old Nov 7, 2004 | 07:34 AM
dIlLiGaF's Avatar
I jusy copied this from TDR site and was wondering if we could install a switch inline with the ground for the apps and use as a cheap high idle feature.
05-28-2004, 02:40 AM #7
Marco
Offline
Ground
I've seen that a couple times.
All the sensors share the same ground circuit. When the APPS has a bad ground connection the Rpm goes up to about 1300.
All those grounds are connected to pin 11 on the ECM.
Most likely it's the engine harness that has a problem.
A simple test could be this. Pin 1 on the APPS is the ground circuit . Try to provide a ground from the battery negative pole to that wire and see what happens. If that works well, then you could simply provide the ground to the APPS permanently from the battery. Been there, doen that....
Marco
__________________
Marco/M.A.D. ECM's
Old Nov 7, 2004 | 07:16 PM
firestorm's Avatar
I do not know, but would like to know myself.
Old Nov 7, 2004 | 08:09 PM
kd460's Avatar
How about a stick propped up between the seat and the go pedal. Is that cheap enough?
My ice scraper works perfectly for this. Kevin
Old Nov 8, 2004 | 08:33 AM
upersleder's Avatar
LOL reminds me of my dad and his 72 chevy. used to have to turn the scraper sideways, cause flat was too much gas.
kicker210
Dec 2, 2009 08:23 AM
Common
Jun 1, 2008 06:15 AM
jmccart
Jun 12, 2007 02:12 PM
five20too
Oct 25, 2006 12:17 PM
99 cummins
Mar 29, 2005 08:24 PM
