pm3 vs edge COMP
Old Jun 28, 2004 | 05:27 PM
00turbo's Avatar
pm3 vs edge COMP
I already have an Edge COMP on my truck but i was looking for a better box. I was just wondering how much power a tst pm3 stacked with an edge EZ or vanaaken box would make. Would this increase smoke becuase with just the COMP i barely get any, and with the tst box would I increase the chance of burning up my VP44?
Old Jun 28, 2004 | 06:19 PM
OldSmokey's Avatar
You tapped the wire right. It should smoke quite a bit. At least mine does. I had trouble with the scotch locks, I could not get a good connection and, I installed a blue chip pump cover and I found out what the box is supposed to do.
Old Jun 28, 2004 | 06:22 PM
gsdog1's Avatar
Me personally, I'd say it is time for some tranny work and injectors!
Matt
Old Jun 28, 2004 | 08:37 PM
joefarmer's Avatar
00turbo -- I've been wanting to try a Drag Comp. I live up in Columbus & would consider trading my PM3 comp for a week. I ain't responsible if you blow up your tranny.
brandon.
Old Jun 28, 2004 | 11:08 PM
DarrellB's Avatar
I just went to a Drag Comp from a PM3 Comp and I really like the Drag Comp. The power comes on much smoother and I can now use the higher levels without freekin out the passengers with the defueling shutter.
I also mad 20 more HP with the Drag Comp over the PM3 Comp/EZ combo.
Needless to say I'm keeping the Edge Box.
DB
Old Jun 29, 2004 | 02:25 AM
PourinDiesel's Avatar
Glad you like it Darrell!!
Old Jun 29, 2004 | 12:25 PM
RowJ's Avatar
Matt's right! Injectors (even a small set) will do more for you than any box combination.
RJ
Old Jun 29, 2004 | 12:36 PM
MikeR's Avatar
Keep the box install injectors and then you'll need a clutch.
dodgediesel
Jul 27, 2007 08:59 AM
dodgediesel
14
Dec 14, 2006 09:54 AM
dodgediesel
24
Oct 25, 2006 04:40 PM
blackdiesel
34
Aug 2, 2006 08:41 PM
rockjeep73
Mar 25, 2005 03:34 AM
