Please Explain!!
Old Mar 7, 2007 | 12:49 PM
Tim @TotalFab's Avatar
Please Explain!!
I was reading an article in the diesel power mag on a 98 12 valve, It said the valet switch cuts the air off to the pump. Just wondering what they are talking about.
Old Mar 7, 2007 | 12:57 PM
Mike D's Avatar
Cuts the air out? I know next to nothing about 12v, but come on! Less air to the pump?
Old Mar 7, 2007 | 12:58 PM
cumminsdriver635's Avatar
There is a line that runs into the AFC housing on the pump. When your motor starts making boost, it pushes a little rubber diaphram in the pump forward, and lets your injection pump start fueling harder to keep it from smoking like crazy right off of idle. The valet switch blocks off that line so that the boost doesent get to the pump, therfore it wont fuel near as hard as what is possible. Flip the switch, it lets the boost go through, and you are back to full power. I have a valet switch on my truck. Kinda fun to play with. When you loosen the starwheel on a 12 valve it makes that rubber diaphram easier for the boost to push forward, which gives you more fuel and smoke on the bottom end.
Eric
Old Mar 7, 2007 | 06:06 PM
clutch1's Avatar
probably the only "flip of the switch" us 12V guys can have.
Old Mar 7, 2007 | 10:39 PM
ratsun's Avatar
Its as close to electronics on a truck as I ever want to get again.
Old Mar 7, 2007 | 10:58 PM
Tate's Avatar
What about the lock-up switch for the autos?
dcwm
Aug 21, 2003 10:03 AM
dcwm
28
May 14, 2003 02:42 PM
RJMontana
Mar 21, 2003 11:20 PM
