.......performance injectors.........
Old Jan 7, 2012 | 11:49 PM
oldkimmer's Avatar
...............Hi there, i have a 2001 2500 4x4 with a 5.9 diesel, auto, built up, has triple disc converter also........i have put on an edge ez and a 4in exhaust....also a holley blue pump in place of factory lift pump.....what injectors do u guys recommend?........where do i buy them?.........thanks.......kim.........
Old Jan 8, 2012 | 08:13 AM
John_P's Avatar
Originally Posted by oldkimmer
...............Hi there, i have a 2001 2500 4x4 with a 5.9 diesel........i have put on an edge ez and a 4in exhaust....also a holley blue pump in place of factory lift pump.....what injectors do u guys recommend?........where do i buy them?.........thanks.......kim.........
Kim:
Give our own Lary Ellis (Top) a call at the "Diesel Truck Resource" Store and he can help you decide what injector you need. Here is the toll free number for you:
1-877-375-1956
John_P
Old Jan 8, 2012 | 07:10 PM
DodgenIt's Avatar
Do you have an auto or manual?
That will determine turbo size and over all what size injecter you can get away with.
Also remember that our stock trans can't handle too much extra power.
Auto has the tiny hy35 and a manual has a more stout hx35.
Over all I'd say with what you have done so far I'd think some F1 or ddp 50 or 75's would be your best choices.
Old Jan 9, 2012 | 11:22 AM
oldkimmer's Avatar
.........Its an auto, built up some, triple disc converter......thanks....kim.......
Old Jan 13, 2012 | 04:52 AM
95ram's Avatar
With your turbo and only having a convertor I would recommend the cummins RV275 injectors. It would be a good 40RWHP bump and cost WAY less than a set of aftermarket. I've run them in a few pickups and they're a good bang for the buck.
Old Jan 13, 2012 | 08:04 AM
oldkimmer's Avatar
................Thanks.........kim.......
Old Jan 14, 2012 | 08:34 PM
DodgenIt's Avatar
Hey yea I forgot about the rv's. I had a set of those for a while. Low cost, no smoke, great for towing.
Those would be a very good choices as well.
I suggest a 3/4 stubby open end wrench and or a 3/4 crows foot on a 3 inch extension to break number 6 free. If your doing your injectors yourself that is.
Old Jan 17, 2012 | 09:45 AM
Tejas TJ's Avatar
You've got the HY35 which will get super hot with just about any bigger injector.
With just the Edge Comp and not on the skinny my pyro will get close to 1100
KRB
May 20, 2007 06:20 PM
DanTana
Nov 30, 2004 02:03 AM
BIGOKIE
Jul 21, 2004 05:53 PM
BigBlue
Jun 3, 2004 04:09 AM
BamBam
20
Dec 24, 2003 08:50 AM
