PDR Master Power turbo(?)
Old Apr 24, 2008 | 06:55 PM
ckt_santiago's Avatar
Question PDR Master Power turbo(?)
Ok, so I need a cheap solution to my turbo problems... My HX40 is not exactly tow friendly on my truck and PDR has a really good deal on their Master Power 66mm turbo ($550) and I was just wondering if anyone has experience with one and if anyone knows how big the exhaust housing is... Basically I just want to know if this is going to spool faster than the HX40 w/16cm housing. It's obvious that it is going to flow more air (60mm vs 66mm).
Any help would be great... Thanks guys
EDIT: I have some custom 6x.009 EDM'd injectors and a three piece manifold on the way. I figure those alone should help with the EGT's while towing (I tow my tractor around all summer), but I need something that flows more air and spools quicker and this is within my budget
Old Apr 25, 2008 | 12:55 PM
Bump... No one has any experience with this turbo?
Old Apr 25, 2008 | 05:22 PM
Sinbadd's Avatar
I've heard they are good turbos, gassers are using them with good results. I haven't heard of anyone on the forum using one though. They are made in Brazil.
Old Apr 25, 2008 | 05:26 PM
CMooreBLKSMK's Avatar
You could probably do a search in this forum and find some info. But I think most of it is bad.
Good Luck
Cory
Old Apr 25, 2008 | 05:30 PM
Big Blue24's Avatar
I've heard they have too small of a shaft for the wheels and are failure prone. One concern is spoolup, it will spool slower than your HX40. The fact that PDR lists it as 450 HP is concerning as well, a comparable 66mm s300 based turbo will be rated anywhere from 6-800 HP, so it has something fishy going on. I do admit, the price is right.
Old Apr 25, 2008 | 06:34 PM
Thanks for the replies guys... I'll just bite the bullet and go with an Industrial Injection SPS62 14 then. I just wanted to see if I could get away with spending less money. I don't race all the time with it, but I am pretty mean to my turbo and am rather surprised the HX40 hasn't crapped out on me yet. I snapped the shaft in my stocker so if this one has a reputation for snapping shafts then I want nothing to do with it. Thanks again guys
Old Apr 25, 2008 | 07:44 PM
HOHN's Avatar
"if it seems to good to be true, it probably is..."
Old Apr 25, 2008 | 08:27 PM
Don Wagner's Avatar
66mm compressor wheel with a P-trim turbine, should spool well with the proper fueling but without a ported shroud compressor surge will be an issue. The 0.25" shaft is weak but if supplied with enough oil they hold up well in their own right.
Old Apr 25, 2008 | 11:07 PM
Big Blue24's Avatar
Hey Don, could a guy port the compressor shroud by removing it and machining some grooves, or is there a special formula and certain gap and location to make effective ports? Just picking your brain, you seem to know alot more than the average guy about diesel turbos.
Old Apr 25, 2008 | 11:29 PM
Don Wagner's Avatar
It could be done with some effort.
Txwelder
14
Nov 11, 2007 04:28 PM
pmtg
Oct 29, 2007 11:44 AM
nascar mark
20
May 10, 2004 02:35 PM
Hawkeye
Sep 23, 2003 08:22 PM
