PacBrake
Old Oct 26, 2013 | 05:22 PM
Bimo's Avatar
PacBrake
99 dodge, has pacbrake on for years. Hadn't drove it much for 2 years.
Started driving it again , pacbrake wouldn't work.
Took it off, cleaned the insides ( where butterfly valve is ) Replaced vac cylinder and Solenoid.
Now it work but does not disengage till :
I unlock toque converter and turn off Pacbrake.
Once the engine gets down to idle RPM's , it disengages.
Any Ideas ??
Old Oct 26, 2013 | 08:12 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
weak vacuum pump......
Old Oct 27, 2013 | 12:08 AM
pind's Avatar
Solenoid hanging up. Take it apart and clean it.
Old Oct 27, 2013 | 08:09 AM
j_martin's Avatar
Like he said. Take it off and pm it on a clean table. The screws are hard to find. (Don't ask)
As I remember, it is a bit sensitive to even torque on the screws, also. Fixed mine several years ago. Never had any more trouble. Gets a squirt of PackBrake lube twice a year.
Old Oct 28, 2013 | 12:48 PM
Bimo's Avatar
Thanks for the responses.
Took it to my son, he adjusted the linkage on the vacuum cylinder shaft.
Must have been out to far going past 90%.
Now it works correctly.
Could be I have lower vacuum preasure from pump. I will check it out also >
Joel Richards
16
Jul 6, 2003 11:36 AM
phildog
May 10, 2003 02:37 PM
dcwm
Apr 30, 2003 01:30 AM
Apr 17, 2003 08:16 AM
Big dawg
Jan 25, 2003 06:19 PM
