P7100 Coversion Kit
Old May 23, 2006 | 11:00 PM
cummnz4x4pwr's Avatar
Originally Posted by JDGnut
Jake.. is that just the mech lift pump.. or the cam.. and the lift pump???
All I can say.. is if my VP craps out.. I'm really going to look into this... Jake's looks very good...
Bryan
If im not mistaken it contains both the cam and lift pump.
hey are you going to hillsboro this weekend.
im not going to be able to make it. but ill definately be in stupidville, next month. hopefully w/ a new clutch and new valve springs so i can turn 4k safely with my setup.
thanks
jake
Old May 23, 2006 | 11:04 PM
JDGnut's Avatar
I'm not sure how long I'm going to be in Hillsboro.. have a wedding to go to.. but I'll take a tractor ... and make a hook.. or two..
Yes.. I'm planning on being in stephenville in June... don't think we'll have a truck... we'll see..
Old May 23, 2006 | 11:29 PM
kelownadiesel's Avatar
I think travjrath was running the fass with the p pump on his wasnt he?
Also what about the injectors,I've heard that there is some contoversy about whether to use th 24 valve injectors or special ones made for the swap due to pop off pressures or something
Old May 24, 2006 | 12:36 PM
Rodram2002's Avatar
Originally Posted by cummnz4x4pwr
oh and with your 2000 model you dont have to put the cam sensor back in b/c you have the crank sensor as well and your tach will run just fine with just the crank sensor.
jake
is it the same setup on the 2002 trucks or do I need to change something?
Kelow- I was told by Scheids that I can use my 24 Valve injectors and they will work just fine. I was also told that they have just used large 24 valve injectors on the trucks they have worked on. said they work great, just smokes alot.
Old May 24, 2006 | 05:04 PM
Actually yes you either have to machine the valve cover to make the cam sensor work or just dont use a tach.
Ive actually developed an adapter made out of aluminum that will bolt on the 12v case after a little die-grinding. but you will not have to weld anything and it would be a very simple install and worth every dime to be able to use your factory tach. and this is not just a butchered piece of aluminum either its cut with a CNC MILL. for factory style fit.
pm me for more info.
thanks
jake
Old May 24, 2006 | 05:13 PM
TxDiesel007's Avatar
Guys
i know that crazy dude 12Valve, has done a P pump conversion for just under 600 bucks, yes you read right, yall might wanna dig up his threads and see what he has to offer, NOw yes i do agree if i ever get a 24V, it will be P pumped as well...
Rick
Old May 27, 2006 | 09:33 PM
24valvepuller's Avatar
the truck will also run great with stock injectors, or at least mine did
Old May 27, 2006 | 09:53 PM
torquefan's Avatar
Originally Posted by storx
all i know is there has to be an easier way to doing this for an cheaper price. the lines are 450 from haisley... thats not the issue but what else comes in the kit that worth the other like 1 grand????? i know the timing cover for the engine dont cost near that much and what year timing cover are we talking about anyways is there a particular year of timing cover to use.
You don't need a timing cover. You need a gear housing.
DODGER BOMBER
Cummins Conversions
Aug 13, 2011 08:45 PM
USMC
Sep 16, 2008 06:58 AM
nofear
Feb 25, 2008 08:46 PM
city slicker
Feb 15, 2007 11:58 AM
storx
74
Sep 24, 2006 02:24 PM
