P-Pump work
Old Oct 17, 2006 | 09:23 PM
Kroner's Avatar
P-Pump work
What should I have done and where should I take it? I think I have a problem with my pump and if it checks out ok im planning on having some extra work done, ie, balancing , ??. Is there anything else I should look into? I know there are a lot of shops around but im not sure where to take it.
Thanks
Kroner
Old Oct 17, 2006 | 11:07 PM
wana12v's Avatar
diesel injection in cincinatti they tuned my pump and did the cut dv's
Old Oct 17, 2006 | 11:08 PM
59Dsul's Avatar
If you're in Evansville, I'd talk with Kolbs. We had them rebuild a pump off of one of our Deere's. They did a great job and service was quick.
andy
Old Oct 18, 2006 | 08:12 AM
Kroner's Avatar
Im in Muncie for school now.
Old Oct 18, 2006 | 08:29 AM
Mcmopar's Avatar
Does the name Scheid ring a bell????
Old Oct 18, 2006 | 09:43 AM
Paul Winey's Avatar
I would put the plate back in (#0 or #100 and yes I know the debate) and adjust it forward. Adjust the governor arm as it is much easier to do when off of the truck (you can do this on your own before the pump goes back on. Then have them turn up the plunger/barrels to max out the fuel. Maybe convert the 3K springs to 4K. See if they can also give you the readouts on fuel levels at various rpms and at idle. May run a couple hundred when all said and done.
Paul
Old Oct 18, 2006 | 06:05 PM
dsl kicks gas's Avatar
there's a place in seymour indiana called Interstate Fuel Injection, seymour is about 30mi south of columbas in, and about 45mi north of lousiville, ky on 65.
here's the # 812-523-3308
or if ya dont like money go to diesel injection in lousiville or cinci.
Old Oct 18, 2006 | 06:33 PM
wana12v's Avatar
there is a guy (cant rember his name now) that works at diesel injection in cinnci and he is a p-pump fiend he maxed out my pump and cut me a set of dv's. he also made me the charger I am running. i think he does the performance work on the side after hours type deal. He came recomended by cousin billy (brc diesel) cuz he does all his pump work
cheese4420
Apr 13, 2008 11:50 AM
96_12V
Jul 7, 2005 11:26 PM
Moose10
Sep 1, 2004 06:01 PM
thumbs
Aug 5, 2003 06:57 AM
