oem air intake
Old Nov 1, 2004 | 06:39 PM
suttonbeeman's Avatar
Unhappy oem air intake
Seems like the more I look the more confused i get. Was told today that you can put a k&n filter in a stock intake and drill some 1" holes in bottom of intake and it will work as good as amy after market performance syste. i dont believe everything I hear but sounds interesting. The guy pulls his truck and is successful....any opinions? Thanks
Old Nov 1, 2004 | 06:44 PM
Dr. Evil's Avatar
Some will disagree BUT a K&N is definitely NOT the best option on a Cummins. They let in WAY too much dirt.
As for drilling the holes in the airbox, yeah you can do it and get a bit more airflow but the fact is, the airbox doesnt seal well at all and this isnt a good option either.
A much better option is a paper BHAF with an outerwares racing prefilter or SCOTTY 2, or an AFE stage 1 or 2 intake with the Proguard 7 filter, all of the above get rid of the crappy stock airbox.
BHAF:
https://www.dieseltruckresource.com/...cat/500/page/1
Scotty 2:
http://www.scottyairsystems.com/
AFE Intake:
http://www.superdutyheadquarters.com/afedodgediesel.htm
Old Nov 2, 2004 | 03:02 AM
willysrule's Avatar
Dr. Evil...
in those pictures of the BHAF where did you get the cover for the filter and the heatsheild...
Thanks...
Old Nov 2, 2004 | 07:29 AM
Dr. Evil's Avatar
Not my setup.....its Phoxes.
But you can get them at: http://www.outerwearsracing.com/
Give them the BHAF part number and color you want and they will ship directly cutting out the middleman.
Old Nov 2, 2004 | 03:09 PM
HOHN's Avatar
Thanks, Doc for saving me the time. I spend a lot of time warning against K&N.
jlh
Old Nov 2, 2004 | 03:51 PM
Mike D's Avatar
Take a looksee here http://www.unifilter.com/automotive.htm
UAP-908 4" 6 1/2" 5 1/4" 11" $49.95
I run this in my truck. UNI is a great filter company. Well known in the motocross/dirtbike, atv, offroad racing crowd. Oil Foam filter.
Old Nov 2, 2004 | 04:44 PM
INJECTOR JACK's Avatar
If you do a site search you will find the heat sheild template.
And you will also get the BHAF part #'s as well as the pre filter #'s
Old Nov 2, 2004 | 05:05 PM
Scotty's Avatar
Top's Younger Twin
UNI is what I use in all my air intake applications.
Old Nov 2, 2004 | 07:22 PM
phox_mulder's Avatar
If I would have known my setup would be referenced so many times,
I would have cleaned up a little before I took the pic.
If UNI is good enough for Scotty, nuff said.
I'll stick with my goofproof paper filter, at least for a while.
phox
Old Nov 3, 2004 | 12:49 AM
Dr. Evil's Avatar
jlh
Yeah me too.
Shaun Cockran
May 8, 2012 05:52 PM
goose2w1
May 16, 2007 06:45 PM
BAJA MAN
Nov 21, 2006 05:49 PM
