nut size??????
Old Jun 4, 2005 | 06:55 PM
caper's Avatar
nut size??????
what size is the nut on the pitman arm on an 02 ??? About to install a DSS I hve the 1 1/4 deep but I need a socket for the factory nut maybe 32,33 mm?????
Old Jun 4, 2005 | 08:41 PM
rockwithjason's Avatar
I believe it was 32mm. At any rate I had to buy a set from harbor freight to get one and if I remember right the 32 fit a little loose so maybe it is actually a 31mm. I didn't have any problems using a 32mm tho. Build on union bro!
Old Jun 5, 2005 | 10:51 PM
caper's Avatar
Thanks J , couldn't find a 32 mm so I gave it a try with a big cresent wrench, came loose way to easy, definitly not 185 ft/lbs like your told to put on the new nut/shaft
ATEAV8GN
18
Jan 24, 2018 12:28 PM
wisconative
May 13, 2013 07:20 AM
Clane
Jun 2, 2012 03:31 PM
TexRam
17
Apr 14, 2003 07:14 PM
ATEAV8GN
Jan 13, 2003 03:24 PM
