HTT Exhaust Manifold
Old May 3, 2005 | 06:19 AM
winner172's Avatar
I got my new exhaust manifold from HTT yesterday and thought I would post a couple of pics.
Oh well, I tried.
They are in my gallery if anyone is curious
Old May 3, 2005 | 08:34 AM
CTD NUT's Avatar
Looks good ......when is the install?
Old May 3, 2005 | 06:32 PM
winner172's Avatar
I hope to install it saturday.
It has two holes drilled and tapped for 1/8" pyro but I will have to drill & tap one of them for my 1/4" probe.
I ordered it pre assembled so that should make the install a bit easier.
Old May 3, 2005 | 07:28 PM
I might have to get one of those! How's the inside look? Is it cast cleaner than the ATS?
Old May 3, 2005 | 09:01 PM
winner172's Avatar
It seems pretty well cast and pretty smooth inside.
I will add some more pictures to my gallery
Old May 8, 2005 | 08:42 AM
winner172's Avatar
Wink
Well, I got the manifold put in.
I put some pictures in my gallery if anyone is interested.
Old May 8, 2005 | 08:57 AM
Looks nice! I'll have to add that to my never ending list of things to do to my truck.
Old May 8, 2005 | 12:28 PM
1320's Avatar
Have you seen a reduction in the egt?
Old May 8, 2005 | 07:57 PM
winner172's Avatar
no, EGT's are the same.
I think the 12cm housing is the bottleneck as far as exhaust goes.
Old May 8, 2005 | 08:08 PM
BC847's Avatar
1st Generation Admin
Those inlet ports look a lot cleaner than the ATS (at least the one I got). The ATS were pretty ragged compared. Had to grind them on down to straighten it all out.
I can't help but think you'll see an improvement in the general spool-up range (not WOT type throttle if that makes sense).
Old May 8, 2005 | 09:15 PM
winner172's Avatar
I guess the only thing different that I have noticed is that I can't hear the small exhaust leaks I had with the shrunken stock manifold.
Old May 8, 2005 | 09:41 PM
timeagain's Avatar
nice!! tell us if it helps anywhere,
Old May 11, 2005 | 09:22 PM
12valve@heart's Avatar
OK, I probably should know this but I don't so I'll ask. What's the difference between the 1st gen. and 2nd. gen 12V exhaust manifold? I see HTT designating this for '94-'02. Why won't it fit my '92?
BTW, did you get the optional HPC coating? If so, how do you like it?
Old May 12, 2005 | 06:24 AM
winner172's Avatar
I don't know about the first gen's but I know they have them for the 12v & 24v.
As for the HPC coating, no I didn't spring for it. Too much money.
Old May 12, 2005 | 04:08 PM
To put the ATS manifold on a 1st gen I've heard that you have to clearance the firewall a little. I assume the HTT manifold is the same way. It will bolt to the head, it just might take a little hammer work to get it there.
