New Water/Meth kit
Old Oct 8, 2007 | 07:52 PM
Why_Try's Avatar
New Water/Meth kit
After debating on building my own i broke down and got a snow stage 2 kit. So far so good. I have to try pretty hard to get the EGTs over 1500. Power might be up a touch but i could probably gain more from turning off the A/C. I suppose the dyno will tell. Defiantly helps for the long pulls on the highway
One thing i learned was, if you mount the tank higher than the injection point (IE tool box), make sure you get the upgraded solenoid. Without it it pisses off the neighbors at 5am when you fire it up with a puddle of washer fluid in the intake.
Now the question is...do I fall into the same group as the nitrous guys .
Old Oct 8, 2007 | 08:53 PM
Dodge359's Avatar
Heck, I run both, couldnt decide which drugs to deal to my truck so why not. Mine makes a 63hp gain on the dyno.
Old Oct 8, 2007 | 09:42 PM
Why_Try's Avatar
Im sure it will come to that. Ill come up 40hp short one weekend, and you know what will happen the following weekend.
First come twins, then come other things.
Old Oct 8, 2007 | 09:52 PM
Dodge359's Avatar
Dont get to hung up on running the expensive meth. The -20 washer fluid works great. One of the canadians was telling me they have -40 fluid. I am going to start running an anti-corrosive/pump lubricant in my system. Take a look at this thread.
W/M rust additive
Old Oct 9, 2007 | 05:30 PM
Why_Try's Avatar
Makes sence. Guess i will stop by NAPA tommorrow.
Old Oct 9, 2007 | 06:15 PM
mopar440cu's Avatar
He WhyTry what are you pulling with your Dodge too get high EGT's? Im also considering the snows or Devils own kit. I pull alot of wieght with our 36 foot gooseneck trailer and mine gets hot!
Old Oct 9, 2007 | 07:47 PM
Why_Try's Avatar
Truck runs hot to begin with. I could hit 1500 if i pulled all the way through 6th with ease.
Towing wise, I pull 9-12K of cars on a weekly basis. It wasn't impossible to drive but i did have to keep my eye on the pyro.
With the meth empty I can still get to 1500 but thats only when i pull 3rd-6th to red line, and its not nearly as out of control as before. Towing is bliss now. Pulling some of the long medium size hills i set at 1250-1300 degrees...and thats just driving. Not trying to dog it or be nice. Big hills fun to watch as the egts will creep to 1200ish, i hit the desired boost to activate the meth (1st stage at 22psi 2nd at 32psi), and i watch it fall to 1000 and creep back up to 1300. I don't see how you can go wrong with it.
Well aside from the fact i popped my head gasket tonight. Not sure if it was due to the meth or just dumb luck.
Old Oct 9, 2007 | 09:47 PM
Dodge359's Avatar
Danged drive pressures strike again.
Old Oct 9, 2007 | 09:48 PM
Why_Try's Avatar
I wonder if i can weld the head to the block.
Old Oct 9, 2007 | 09:50 PM
Dodge359's Avatar
Now you have a reason/excuse to put the twins together.
Old Oct 9, 2007 | 09:53 PM
Why_Try's Avatar
See i like the way you think.
Old Oct 9, 2007 | 09:59 PM
Dodge359's Avatar
If you have another head (not o-ringed) you could try the cometic head gasket.
Old Oct 9, 2007 | 10:04 PM
Why_Try's Avatar
Yea no spare heads laying around. There has to be something out there that will hold up to my way too much timing and injection of drugs. And to think last night i was looking at putting together a nitrous kit. Maybe this is Cummins telling me "Stop screwing with a good thing, IDIOT".
Old Oct 9, 2007 | 10:11 PM
Dodge359's Avatar
What are you timed at? Maybe that would solve some problems. Very important with the nitrous.
Old Oct 9, 2007 | 10:21 PM
Why_Try's Avatar
Honestly I dont know. Going to give Scheid a call tomorrow and see what thier suggestions are. Also find out what they time the HRVPs at. Plus the EZ on smoke.
