new VP44 and it wont start
Old Sep 29, 2007 | 09:10 PM
TheMighty'67's Avatar
I just put in a new VP44 and put everything back right, and now its not starting. It is getting fuel so i checked for codes and got
P 0122 throtle posistioning sensor volts to low
P 0123 " " high
P 1693 DTC Detected In ECM Or PCM, and is says soething about companion mode ?
Please P.M. if you could help, I need my truck for work
thanks, Dayton
Old Sep 29, 2007 | 09:25 PM
i reset the computer and now all i am pulling is the P 1693
Old Sep 29, 2007 | 10:12 PM
TXaggie09's Avatar
P 1693 is a compainion code, you will need to get a code reader to pull the actual code. Might be a stupid question but did you bleed all the injector lines and everything?
Old Sep 30, 2007 | 09:31 AM
yeah what im going to do is take it apart and put the piston #1 to TDC and then it should be timed, all i did was put the keyway on the injection pump gear at 12 o'clock
Old Sep 30, 2007 | 10:09 AM
westexhunt's Avatar
timing is a non issue
On the vp44 as long as the keyway and key line up, and you don't shear the key, it makes no difference if you are at 12o or not. I always crack three lines, crank till fuel stops bubbling, tighten them up and it starts right up.
Old Oct 1, 2007 | 01:50 AM
AlpineRAM's Avatar
The first codes look like the APPS (or TPS) being unplugged- take a real good look at the plug and the cable.
Old Oct 1, 2007 | 08:38 PM
Hey yall got her runnin again, thanks for all the help
Old Oct 1, 2007 | 09:02 PM
westexhunt's Avatar
What was it?
grunthmc
Aug 4, 2011 07:46 PM
quads4_life
May 1, 2010 12:54 PM
4969joes
Mar 18, 2010 10:19 AM
qcstunter
Jan 9, 2007 04:10 PM
Andy505
Nov 15, 2005 06:49 PM
