Bled system...truck wont start...VP44?
Old Nov 15, 2005 | 05:26 PM
Andy505's Avatar
Well fellas...recently i had the in-tank retrofit system installed on warranty...and I had low fuel pressure....so i custom made a harness so I can run the regular LP and the in-tank pump at the same time....I bumped the starter and It went up to 16 psi almost immediately...so then I bled the VP just like I have done many many times before, and no start. I figure I was getting too much pressure so I unplugged the fuse for the in-tank pump so just the regular LP would run, I had about 7-8 psi on the guage which is lower than the 3-5psi I was getting before this project. So then I did the same bleeding prossess that I have done many many times before and...no start...so I crack another injector...no start...now i have injector 1, 3 and 4 disconnected...normally i have just 1 & 3 when i bleed the system....well then I closed injector #1 then I tried and it fired up!! on just injector #1 and ran for about a second then died! So what is this??? Now I just turn it over and over and over...but no start. any suggestions??? is my injection pump toast? or what? It is still under warranty and I am glad atleast I am home. Instead of on the road...like I would have been this weekend.
Old Nov 15, 2005 | 06:09 PM
Andy505's Avatar
I am getting fuel to the injectors that i cracked...it does not spray out like normal though...It just leaks out.
Old Nov 15, 2005 | 06:25 PM
J BODY's Avatar
It may be the pump. I take it on the loose ones you do see some fuel coming out as you are cranking, but the volume just isn't there. I had a truck towed in from a quick lube just last month that did that. Poor guys put a fuel filter in it and thats where the VP decided to die. I put on a lift pump as the one on the truck was dead, primed it, loosened the same lines you accessed and only got a little bit of fuel flow. Installed a VP and when I cranked that one up the fuel flow was quite obvious. Hopefully you'll have a tech that can see beyond the "no code" issue and fix your truck.
Old Nov 15, 2005 | 06:49 PM
Andy505's Avatar
I tried resetting the APPS https://www.dieseltruckresource.com/...n&onlynewfaq=1
and cranked it over...and ITS ALIVE!!!
now lets see how long it runs....hopefully it doesnt break down on my run this weekend.
quads4_life
May 1, 2010 12:54 PM
dieselcarpenter
Jan 21, 2010 12:42 PM
TheMighty'67
Oct 1, 2007 09:02 PM
Munchies
Feb 12, 2007 10:44 PM
qcstunter
Jan 9, 2007 04:10 PM
