New Turbo??
Old Dec 20, 2007 | 09:03 PM
1BAD4X4's Avatar
What about 500rwhp with a 24v that doesn't tow? A little bit of lag isn't that big of a deal. I just want to hit 500rwhp with ease... anything else is just icing on the cake.
Old Dec 21, 2007 | 08:54 PM
Mike Holmen's Avatar
The Guru
If your gonna tow a heavy load and be in the 500rwhp, twins is the way to go. Yes, the laggy single isn't a big deal most of the time, just when you need to accellerate quickly.
Old Dec 21, 2007 | 11:12 PM
Tate's Avatar
62mm will do it for you. Something in the 71mm or 74mm turbine variety.
Old Dec 22, 2007 | 08:24 AM
schoust's Avatar
I like my 62ss but if I had a choice I would definetly go with the twins! The turbo is a tad slow to spool but once there it's a outstanding! I also think with more timing and more fuel I would like it more....
Old Dec 22, 2007 | 06:41 PM
Hayseed's Avatar
schoust, did you finally get that turbo straightened out? Mine is good but I let the wife and son talk me out of the truck!! I'm running a STOCK 6.7 for now!!!!!
Old Dec 23, 2007 | 09:59 AM
OWEN B's Avatar
Does anyone make a turbo that would work well with my trucks set up and still be able to use my exhaust brake
Old Dec 23, 2007 | 01:44 PM
schoust's Avatar
Ya Hay it's all good I had to simply learn how to drive it! I mean you just can't mash it from a dead stop and expect the tires to spin! That 71 wheel is a whole differant animal than the stocker. I like it a lot now I just wish I had some bigger injectors to try! I'm on the hunt for a set of good used 435's keep your eyes open for somthing in this area of flow. Ralph
Old Dec 23, 2007 | 02:33 PM
bridleman's Avatar
Originally Posted by aksparkey01
west coast, i did quite a bit of research on this also before choosing my turbo. i went with the new htt 62/13/71 because the 13 sounded like a good compromise between the 12 and the 14. its only come in the stainless though. from what i saw before my head gasket went i really liked it. it was a little slow off the go if you just slam the go petal but with the 5 spd you can run right in the sweet spot with it. also you have the 4k gsk advance that timing some more and i think you will find a better top end power with a slower spooling turbo. but when the 62/13/71 lights off it goes fast and hard. "they said it is set at the factory at 42# first time i mashed the petal mine hit 60#." I have also heard really good things about the silver bullet, that was my second choise. garret was the best price on the htts that i found. hope that helps your decision
I know that you are speaking of a 12v but my 24v has never seen over 44psi with this turbo (62/71/13ss) I have done everything to get more boost even plugging the w/g with no change, the only thing I can think of is it's not enough fuel but it seems that everyone who has this turbo has no prob hitting 50+psi I guess we will see if it's a fueling issue when I get the Mach 4.5
Old Dec 23, 2007 | 03:25 PM
Ph4tty's Avatar
Using a Dodgezilla or getting your upgraded to a 35/40 are the only options I'm aware of unless you want to build a custom downpipe like Jlent.
Old Dec 24, 2007 | 10:38 AM
The Guru
Why can't you spin the tires off intial spool-up.
Has anybody seen the compressor map for the s300 62? What kinda off speed is compressor spinning at when your in the mid 40's for boost. I bet that your almost at the top of the map. You really need a steep compressor map with more pressure ratio to break thru into the 50psi area for a single turbocharger. Of course twins would still be pulling hard until the 80psi area with a S400 on the bottom, tons of cool air for pulling. I would also reconfigure the S300 for twins application so your spool-up would remain the same but you would still have good cool air until 70-80psi range.
Old Dec 24, 2007 | 11:29 AM
Ph4tty's Avatar
I think you're right Mike, even if we have to guestimate due to a lack of published maps. The only problem with a 62/13 spinning 44 psi is that its not using that expensive wastegate thats on there.
Old Dec 24, 2007 | 03:29 PM
aksparkey01's Avatar
after i put my 62/13/71 and hit 60# with it right away i emailed htt to ask them where they recomend running that charger. they told me that it is most efficent between 40-45 # but can go up to 60#. so after i get my new head on right i will turn it back down to probally 48 or 50. i havent tried the methanol with that charger but with my stock charger it brought my overall max boost up 7-10 #
CumminsRedneck
Feb 18, 2013 07:51 PM
hoot
Apr 16, 2008 10:08 PM
Ada381
Feb 10, 2008 07:58 AM
kawi600
Jun 21, 2006 06:48 AM
HOHN
28
Jul 6, 2004 04:38 PM
