new truck question
new truck question
im lookling at my 1st CTD ( i'll let u know 4 sure if i get it ). anyway its a 97 12v,and the guy said soon after he bought it he took it and had the pump turned up. whats that mean or is that just a line he is feeding me ?? ive heard of that being done in big rigs,mack,petes,etc.. wasnt sure about these trucks though.also what would adding a set of 375hp injectors do asfar as power goes. it has a k/n,everything else is stock ( except 4 the pump being turned up ) 5 speed ....thanks guys,scott
Re:new truck question
thats the way they turn up those undervalvers instead of gettin a fuel box
. the injectors should get you some more power how much i'm not sure one of the 12v people should knoww
If it was easy to "turn up the P7100" injection pump, I'd have done mine already. Unless the owner paid good coin, I doubt it. Ask him, "Who turned up the pump"? Second, if the pump was turned up, are there gauges? Adding more fuel without gauges is not being responsible. So, if someone did add more fuel (turned up the pump) and didn't install gauges.... I would be cautious. Figure about 40 hp for the 370 injectors. Also, 12 valve = properly valved 8).<br>John
[quote author=dodgeman01 link=board=7;threadid=10944;start=0#104499 date=1045201091]<br>I thought it was easy to turn up the p7100 pump. I did mine when I was 16 years old<br>DM01<br>[/quote]<br><br>Me too! 8)
Yeah but all you all did was move the fuel calibration plate like most of the rest of us. Isn't there a way to turn it up by volume on a flow bench or am I talking out of my a#! here?
Guest
Posts: n/a
Fuel calibration is key. However, if the fuel was properly turned up, you would know it. There are parameters inside the pump that allow more output. These have to be done on the flow bench. How else do you think 600ccs is possible? ;D<br>You would be wasting your time changing fuel plates. Fuel plates are just a cheap way of "turning the fuel up," which isnt even what you are doing. Unless the pump has been on a bench, it has not been "turned up." Anyone can move a plate forward. [undecided]
GrumpyTX
Aug 3, 2007 02:40 PM
b.white
Mar 20, 2007 05:28 PM
dcman27
Jun 21, 2004 06:48 PM
