New track bar options?
Old Apr 13, 2011 | 08:49 PM
kevellis32's Avatar
I need to get a new track bar on my 98. I have no interest in spending 500+ dollars for the track bar and conversion kit if it is not necessary.
I have read that the moog track bars will work just fine on my truck, BUT, do I also need to buy a conversion bracket that companies like Carli, Kore, Thuren say is necessary? or will a moog work just fine and not go out on my like the previous 2 I have put on.
The truck has a leveling kit on it and 315/75/16 tires.
Old Apr 14, 2011 | 10:10 AM
infidel's Avatar
Unless your truck is lifted and you need an adjustable there is no reason at all to spend big money.
One of these will give you several hundred thousand miles with no problem> www.lukeslink.com
Old Apr 15, 2011 | 11:39 AM
kevellis32's Avatar
will a leveling kit count as a lift?
Old Apr 15, 2011 | 01:26 PM
ranchertx's Avatar
If you have a leveling kit, it is lifted. Get a thuren or some other kind of adjustable track bar. Otherwise the axle will no be centered correctly, and sooner or later, the death wobble bug will get you.
Old Apr 15, 2011 | 04:39 PM
kevellis32's Avatar
Darn, really didn't want to have to spend that much. I looked on thurens website and it appears that I don't need a conversion bracket, so that will make it cheaper.
Weird thing is, I have put 175k on that truck with the leveling kit and 315's and have never had the so called death wobble and I know my axle isn't centered correctly.
Old Apr 15, 2011 | 05:00 PM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
Same here, but IMO you're better off fixing it before it happens. Parts wear out very quickly once death wobble occurs. Also, I can almost guarantee you'll feel a big difference as soon as you install a good one. Here's a link to my thread when I put one on my dad's 99.
https://www.dieseltruckresource.com/...w-t279658.html
Old Apr 17, 2011 | 07:17 PM
LOWTYD's Avatar
Ditto
Go ahead and put the Carli bar on.....170,000 on mine. No DW since installed. Also, tires can be a major contributor to DW. Good luck..
Old Apr 17, 2011 | 08:02 PM
Silver R/T's Avatar
Where do you get "Carli" bar?
Old Apr 17, 2011 | 08:36 PM
Danderson's Avatar
I did the DSS conversion and stock 3rd gen trackbar on my '98.5. I didn't have luck at all with the Lukes Link. If I had to do it today, it would be the Thuren bolt-in.
Don's stuff works,
Old Apr 18, 2011 | 09:56 AM
rebal's Avatar
I have had realgood luck with the MOOG DS1413 been on for 6 years now and still good
Old Apr 19, 2011 | 11:46 AM
SIXSLUG's Avatar
I have the Thuren w/o the third gen conversion. Its bullet proof and reasonably priced, at least it was back when I got mine.
Another good reason is you call their number and Don Thuren answers the phone. He knows his stuff and is very helpful.
Old Apr 19, 2011 | 01:29 PM
IanM's Avatar
Rebal,
Is that track bar adjustable?
Old Apr 20, 2011 | 11:12 AM
kevellis32's Avatar
Thanks for all of the input. I think I am going to go with the Thuren track bar (it doesn't need a conversion bracket, correct?), and at the same time go ahead and get the Carli performance 2.0 package for the 2010. Today is a cheap day
Old Apr 21, 2011 | 08:49 AM
rebal's Avatar
Originally Posted by IanM
Rebal,
No, it bolts in just like stock
Old Apr 21, 2011 | 01:04 PM
kawi600's Avatar
I got a 3rd gen thuren with a converter bracket in place of the frame mount. Real good so far but the whole deal was expensive like you say.
The lukes link is good stuff, but youll need something longer for the lift. There are cheaper ones with adjustable links.. or if youre handy you could weld something up.
RWDCelicadude
Feb 23, 2013 09:10 AM
CTD2001
Aug 22, 2009 10:03 PM
Dinner
May 29, 2007 02:02 PM
kwillis-a
Jan 25, 2007 09:10 PM
mdq
Feb 10, 2003 02:00 PM
