New style, Trans temp adapter.
Old Dec 25, 2006 | 10:59 AM
mrwaters's Avatar
I was looking through Genos garage and noticed a new trans temp probe adapter that clamps on one of the trans lines it says its very accurate, Has anybody used it or what do you thing about it. I am thinking about it because I like the idea of not opening up any points to cause a problem down the road.
Here is the link
http://www.genosgarage.com/prodinfo....CUTEMP_ADAPTER
Its kind of expensive, If I dont do that I will just splice in the the rubber line comming from trans air cooler that adapter is only $10.00
http://www.genosgarage.com/prodinfo....ber=VULCAN_VTA
thanks for your comments
Mike
Old Dec 26, 2006 | 09:31 PM
Fugly YJ's Avatar
I have your 2nd link in mine. Seems to be accurate, and you can't beat the price.
Old Dec 26, 2006 | 09:39 PM
Sea:\>Drive's Avatar
Santa Claus just brought be the vulcan T (2nd link), although I've got to get my gauge too. I didn't have too much worry about cutting the rubber lines.
I would think the 1st link could be useable as long as you're not concerned about the exact number, but just a change from the normal, although I'm not sure how long it would take to register a quick temp change if you're heating her up. Remember, something is better than nothing.
I'd rather trust something that is touching fluid, not going through one metal line and transferring through another big hunk of metal.
Old Dec 27, 2006 | 09:55 AM
infidel's Avatar
Beside being way too expensive the device in the first link would probably be very slow to respond since it's not in the fluid flow. Tranny temps can easily skyrocket in a matter of seconds.
Old Dec 27, 2006 | 10:37 PM
tookmyname's Avatar
I welded a bung into my pan because I plow I chewed thruogh 1 tranny before I did it and i've seen my new tranny jump from 160 to 230 in seconds i did weld an extra skid plate to protect it i'm using autometer gauges i've never trusted electrics
Old Dec 28, 2006 | 06:05 PM
mrwaters's Avatar
Thanks for the comments, I am going to go with T in return line from the trans air cooler.
Mike
Old Dec 29, 2006 | 08:18 AM
Most will tell you to put it in the "hot" line, not the return line as you'd want to know the temperature before it was run through the cooler.
klx650a2
Feb 18, 2008 11:13 AM
t-boe
Oct 13, 2007 06:46 PM
mjsandt
Aug 24, 2007 09:42 AM
04.5HO600
Jul 4, 2007 01:42 AM
supercharger
Jan 31, 2007 09:54 AM
