new sticks.soaked with diesel????
Old Mar 12, 2007 | 09:56 PM
ramroamer's Avatar
Just got my injectors in the mail, THey are in the Bosch box and the part numbers are good but they appear to have diesel on them in the plastic bags and no protective tips on the nozzles. Is this normal?
Old Mar 12, 2007 | 10:00 PM
mysterync's Avatar
If you got them from a major vendor they should have red covers on the tips! I've always known new injectors to have some kind of lube or protective oil but i've never encountered diesel fuel! I'd call and ask just to be on the safe side!
Old Mar 12, 2007 | 10:11 PM
ramroamer's Avatar
Any input from people who got 300hp bosch injectors? Thanks myterync.
Old Mar 13, 2007 | 12:26 AM
ellerman's Avatar
The shop I had build my injectors pop tests them using diesel so I don't think that should be all that unusual. Also, the injectors you got are probably a new tip assembled on an exchanged body. If you bought them from a shop I don't think I would be that concerned. I've never tried to clean all the grime off a used injector tip but I think it would be fairly obvious if they were used. Eric
Old Mar 13, 2007 | 04:26 AM
AlpineRAM's Avatar
Pop testing and controlling the spray pattern is usually done with diesel. They do not clean the diesel from the injectors to avoid corrosion.
AlpineRAM
Old Mar 13, 2007 | 08:12 AM
mysterync's Avatar
Good point guys!
Old Mar 13, 2007 | 12:03 PM
ramroamer's Avatar
Thanks for input fellas.
Old Mar 13, 2007 | 12:13 PM
bnold's Avatar
No protective tips is still a little odd to me... Have recieved three sets of injectors from 3 different vendors all had the same red protective tip...
hot rod al
May 27, 2010 11:39 AM
timberfalls
Nov 12, 2008 07:34 AM
jim2000
Apr 6, 2008 11:47 AM
trik396
Nov 2, 2006 05:58 PM
hellotbone
Jun 30, 2004 02:24 PM
