Truck Floor SOAKED and Musty Smell
Old May 6, 2003 | 01:17 PM
hellotbone's Avatar
My truck has this nasty musty smell from the passenger side and the floor under the carpet is absolutely soaked. I have not used the AC yet this year and the heater core is good.
Old May 6, 2003 | 02:00 PM
dodgeman01's Avatar
Re:Truck Floor SOAKED and Musty Smell
Try looking at you back window or the brake light up in top of the back glass. Both of mine leaked at one time. Tighten the brake light up a little and put a bead of sylcone *sp around both.<br>DM01
Old May 6, 2003 | 02:04 PM
GrandpasRam's Avatar
Unless you have done some creative plumbing, it has to be coolant. If it is not the heater core, then a hose connection to it, a hose itself near the connection point..something of that sort; as far as I have ever seen, that is the only liquid entering the truck cab (other than your coffe cup or soda water bottles). Remember that the A/C uses gases that are only in liquid state while under pressure, so it is not going to be refrigerant - that only leaves coolant.
Old May 6, 2003 | 02:13 PM
hellotbone's Avatar
Its the AC drain off valve its plugged and I got it all fixed up now ;D
Old May 6, 2003 | 02:25 PM
dodgeman01's Avatar
By the way if you floor is wet you might want to take a look at the floor pan under the carpet. Mie was really rusty so I gutted the inside of my truck and sanded and painted it. Take a look at the back glass or roof brake light. That is where the water came from mine.<br>DM01
Old May 6, 2003 | 02:43 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Yep that third brake light will leak like a sieve and pool the water under that passenger seat like that.
I hadn't thought of the condensation problem, Jamie, thanks for the update - I'll have to remember that. Learn somthing new every day.. that is what I like about this site.
Old May 6, 2003 | 05:13 PM
BigBlue's Avatar
I had something similar to that. Just not that bad. Came from the bottom right of the cup holder this morning. Went on a 3 hour round trip yest. with AC set on MAX. Started the truck up this morning, and there is a nice little stream of water coming out. It's not coolant. It is water. Where is the weephole for the AC condenser? Maybe I should just take a look at it and see if it might be clogged.
Old May 6, 2003 | 09:01 PM
Stamey's Avatar
[quote author=BigBlue link=board=13;threadid=14425;start=0#135522 date=1052259215]<br>Where is the weephole for the AC condenser? Maybe I should just take a look at it and see if it might be clogged.<br>[/quote]<br><br>BigBlue, check these out. The first one is looking up from the bottom, under the right fender at the firewall.<br><br><br>The drain is right behind the filter drier (thing with the green plug on it in the pic).<br><br><br>Chris
Old May 6, 2003 | 11:07 PM
BigBlue's Avatar
Thanks for the pics Stamey. ;D
Old May 7, 2003 | 07:01 AM
hellotbone's Avatar
Thats what I drained on mine that plug! That bugger gets crap in it.
Old May 8, 2003 | 07:34 PM
Deer716's Avatar
I recently had the same problem but I had been runnung my a/c. All I did was added a 6&quot; hose to the end of the drain and that took care of it. What was happening was when it was trying to drain it would flow down the underside of the drain back to the passenger side floorboard.<br><br> Ruben
Old May 11, 2003 | 03:14 AM
pwabbott's Avatar
Don't let any moss grow under your feet.<br>
Old Jun 27, 2004 | 02:43 PM
AggiePhil's Avatar
OK, two questions...
1) How can you tell if the cargo/brake light is the source of the leak?
2) How can you unclog the AC drain tube if that's the problem? I have no ShopVac.
Thanks all.
Old Jun 27, 2004 | 05:14 PM
Admin Team Leader
Thanks all.
I took a phillips head screwdriver and removed the lenscover on the cargo/brake light. The plug inside that it attaches too, was wrapped in foam rubber to keep from making any noise. It was soaking wet and obviously a leaky source.
The gasket itself looked really bad as well.
