New Smarty
Old Apr 17, 2007 | 05:22 PM
4x4turbo's Avatar
New Smarty NEED HELP
Just got my new smarty. Can anybody tell me how do I run my Edge comp With the smarty. Can I use the smarty timing and the Edge tapped to the injection pump only, or do I have to use Edge timing and tapped injection wire. Please Help
Old Apr 17, 2007 | 05:31 PM
haloman's Avatar
Smarty on even settings = fuel only. Cant use both timing programs.
Old Apr 17, 2007 | 06:05 PM
4x4turbo's Avatar
Pluged in Smarty ,got- Warning Vin # Locked What do I do now
Old Apr 17, 2007 | 06:29 PM
4x4turbo's Avatar
I talked to Bob. Sending me new Smarty. Thanks To All
Old Apr 17, 2007 | 08:03 PM
blackdiesel's Avatar
Registered
Was it a used smarty?
Old Apr 17, 2007 | 10:10 PM
Bob Wagner's Avatar
long story short. I had a full timer rv'r in nevada that had an obd port problem.
The first smarty did not work do to poor obd port connection. so I sent him another new smarty to verify it was not a smarty issue.
so it was confirm a truck issue and the first smarty was sent back and obvious got vin locked
This was sent out as a loaner not a new for sale as new box.
I missed the ball and did not check the lock as it was sent back by a very good member and no need to check
Oh well chit happens and I will get it unlocked from the samr guy he was as confused as he said it never powered up and obviously it did and lock
No harm or foul and life is good.
Old Apr 18, 2007 | 10:15 PM
bridleman's Avatar
I'm hearing from some guys that the smarty doesn't really like the edge comp stacked. Any thoughts?
Old Apr 18, 2007 | 11:13 PM
Ph4tty's Avatar
The smarty uses a dynamic timing program, but if you set it on the even levels and use the edge for timing you lose that feature and use the edge's timing instead.
stock03
34
Apr 21, 2011 07:40 AM
RyeThomas
40
Apr 20, 2007 10:12 PM
BigBlue
Nov 22, 2006 02:46 PM
bnold
39
Jun 4, 2006 08:21 AM
CTD_Neil
Feb 23, 2006 09:27 PM
