New revos installed
Old Oct 13, 2004 | 11:36 AM
fireram's Avatar
Talking New revos installed
Just had my new LT285 75 R16 Bridgestone Dueller Revo,s installed this morning.
No noticable power loss,
Wheel well to ground incresed 2 inches to 40inches
Wheel center to ground incresed 1 inch to 16 inches
No tire rub at full turn while up on curb
No noticable tire noise up to 100km/ph, 60 mi
Speedo out 5km at 80, and 10km at 100, as per GPS
Going to go out and play with them this afternoon, Will update how they do off road, if I can find some mud.
Wheel balance was not bad, about 5 ounces on two tires and 2.5 on the other two, I should have had them try rotating the tire on the rim, but they were quite busy.
I replaced the tie left and right tie rod, the track bar and the drag link before hand. Parts came to 650 cdn inc the 15% tax.
Tires came to 1150 Cdn with tax, balanced and installed with an 80 dollar alignment, i did not need.
I put the new parts on myself and measured with a tape, the toe on the front tires. I adjusted it to within 1/8 of an inch, figured the computerized machine would correct it anyway. And the alignment guy moved the adjustment sleave less than 1/4 of a turn. Not sure if the guy before me had ever replaced any steering components, but the tech said is was as close as the new trucks he has seen.
I will also post a pic when I get one.
Thanks to all the folks who posted tire and steering info here , It was big help deciding what to do with my crappy old tires and sloppy steering....
Old Oct 13, 2004 | 03:26 PM
GO 4LO's Avatar
Re: New revos installed
So you installed a 1" lift also?
Chris
Old Oct 14, 2004 | 09:41 AM
fireram's Avatar
No, i increased my tire size from bald 265 75 r16 firestones, I have a slide in camper currently on the truck as well.
I measured from ground to top of wheel well before and after the tire switch just to see how much of a change there was if any. Many times the printed tire size in the brochure is off from actual sizes.
Old Oct 14, 2004 | 03:53 PM
DRM's Avatar
DRM
I found out about the Revo's when researching tires for the wife's Expedition and found out pretty fast that EVERYONE who has had a set loves them.
We have had them on the Expy for a year now, and I just had some put on the mother-in-law's Explorer as well. VERY nice ride, quiet too considering the tread.
Not sure how they would do if you actually do any pulling or towing, so I doubt I will be putting them on my Dodge... but a great tire still!
Old Oct 14, 2004 | 03:58 PM
GO 4LO's Avatar
But if wheel center to ground was 1" increase,
and wheel well to ground was 2" increase,
then wheel well to wheel center is 2-1=1" increase, right?
Tires wouldn't affect that measurement. I just figured maybe you forgot to mention putting in spacers or something...
Chris
Old Oct 15, 2004 | 11:12 AM
mic646's Avatar
I put the Revos on mine on Tuesday. So far I like the way my truck handles and rides. My last set, Les Schwab tires that were supposed to be their top tire, lasted about 21k and less then 2 years. So I am hoping to get a little better out of this set. Dealer gave me 30 days to try them out and if I don’t like them or hear too many horror stories about them I can take them back for a full credit.
It was a tough choice between the Revos or the BFGs A/T.
rjm022
Nov 23, 2006 11:29 AM
RonP
Mar 24, 2006 06:04 PM
coobie
Jan 23, 2006 08:08 PM
coobie
Jan 7, 2006 07:24 PM
FiverBob
Feb 2, 2003 02:00 PM
