New injector nozzles and now hard start
Old Feb 7, 2007 | 07:00 PM
roberts11260's Avatar
new vp/FASS/Nozzles/Cam sensor now hard start
Is it possible they could be leaking? the truck runs real good but cranks for about 10 seconds before starting, any ideas
When I put it all back together it would start fine but today it would not start, for about 10 seconds?
Great pressure at the vp44 21lbs.
Thanx
Old Feb 7, 2007 | 07:43 PM
blackdiesel's Avatar
Registered
sounds like youve got a bad o ring one one of your flow tubes IMO
Old Feb 7, 2007 | 09:22 PM
O ring
Im not sure what you are refering to.
please forgive me im still learning the lingo on this diesel stuff.
thanx Steve
Old Feb 7, 2007 | 09:28 PM
Registered
thanx Steve
ya know the lil tube you had to take the injector line off of and pop out in order to take the injector out? Thats your flow tube. you may have nicked one of the o-rings on one of them
Old Feb 7, 2007 | 09:30 PM
Ok gotcha
I was going to pull all of the injectors anyway so when I do ill check all of the O rings.
Old Feb 7, 2007 | 09:39 PM
Registered
Ok gotcha
id check the o rings on the flow tubes first! you may not have to pull the injectors....
i had the exact problem your describing when i installed my mach's. i knew it wasnt the injectors, so i pulled the flow tubes and i had 2 that had nicks in the o rings
Old Feb 7, 2007 | 10:33 PM
CTD01's Avatar
O-rings
When I did my injectors I replaced them. I got them from cummins for like $8.00
Old Feb 7, 2007 | 10:40 PM
CTD01
Did you replace the o rings that were on the injector as well as the o ring on the flow tube?
thanx
Old Feb 7, 2007 | 11:17 PM
CTD01's Avatar
Yes
Yes I replaced both.
Old Feb 7, 2007 | 11:45 PM
Should I post everything I own on my Sig? or just the stuff I have Done to my Cummins turbo Diesel?
Old Feb 8, 2007 | 07:01 AM
crobtex's Avatar
New O-rings and washers are cheap compared to the problems that one little "nick" can cause. Cummins Southern Plains in Mesquite is probably your closest place to get them.
Old Feb 8, 2007 | 07:20 AM
Forrest Nearing's Avatar
we usually go to the one on Irving Blvd. the people walk backwards in Mesquite
Old Feb 8, 2007 | 08:07 AM
dzlfarmboy's Avatar
Yeah most likely one of your cross over tubes is not sealing letting air through and it's try to get it out those first couple seconds of cranking. I had the same problem when i pulled the head for o-rings and a new gasket
Old Feb 8, 2007 | 08:36 AM
I laughed... HARD!
Old Feb 8, 2007 | 11:39 AM
Mike D's Avatar
Originally Posted by Forrest Nearing
I laughed... HARD!
me too....
