new b question
Old Nov 27, 2005 | 07:59 PM
jlarmour's Avatar
new b question
I've been searching and can't find a direct comparison as far as a fueling comp vs going with bigger injectors on a 24 valve. I understand if you get injectors you need something to advance timing, but I'm looking into around 300 horses? (preferably without tapping pump wire---that sounds scary!) I want a good driver with longivity as well as get up and SMOKE when I want it. Also sound like I need a vb at least on my auto tranny. Any ideas would be great. Have to beat the psd wife is in!!!!!
Old Nov 27, 2005 | 08:28 PM
Mike Holmen's Avatar
The Guru
I would buy the comp box and just don't plug it in the pump. As far as 300rwhp, thats pretty easy. Run that box with a set of 100-125rwhp injectors. I made 245rwhp with an ez box and 275 with an ez and a set of 40rwhp injectors. You could make your number easy with just the comp box, on stock injectors but then your hooked like the rest of us. I been thru three injection pumps but I need a fast big hp blast to make me smile after a tuff day in the office.
Old Nov 27, 2005 | 08:40 PM
jlarmour's Avatar
I was leaning more to the injectors and something like the EZ(not sure what mabey catcher/mad ecm?). I don't want to have to replace vp44 every time I turn around. Would something like that be enough to make quite a bit of smoke and out do the beefed psd? Exhaust is actually my next purchase. I want stacks. As for the tranny would I be able to get by with just the vb on 300 horses? I wouldn't trust the stock one with any more hp than what is has. I'm new to dodge so be gentle!
Old Nov 27, 2005 | 10:41 PM
rebal's Avatar
Catcher and a set of mach1.6 injectors will blow that psd out of your way and its safe on the VP
Old Nov 27, 2005 | 10:48 PM
jlarmour's Avatar
Cool, that is what I was really leaning to, I just wasn't sure if that would be OK. Now what about the tranny?
Old Nov 27, 2005 | 10:55 PM
rebal's Avatar
if your tranny is a stock auto. it will kill it in short order you will need a VB at the least
Old Nov 28, 2005 | 05:01 PM
jlarmour's Avatar
OK, Now what order should this be done in? Tranny, box, then injectors? Or injectors then box? Who makes a good inexpensive valve body for the tranny?
Old Nov 29, 2005 | 12:09 AM
rebal's Avatar
DTT will get the tranny parts to you I would do it first because the catcher WILL kill that stock tranny because of the massive low end power it gives.
1 tranny-2 catcher/or box-3 injectors
http://www.dieseltrans.com/dodge/index.htm
Old Nov 29, 2005 | 09:05 AM
jlarmour's Avatar
Great, thanks for the help Rebal. Now I feel comfortable about where to start!
Old Nov 29, 2005 | 11:01 AM
rebal's Avatar
theres no cure fore the BOMB bug!!!!
Old Nov 29, 2005 | 01:42 PM
Jetpilot's Avatar
You should do the tranny first. Then add the box or catcher this will allow you have more air to help with increase fuel of the larger injectors. As mentioned a great setup is Mach 1.6 injectors and an EZ or Catcher.
Also as rebal mentioned give DTT a call and speak with them. I have abused their trannies for over 5 years now with no failures! This is in trucks making in excess of 800 RWHP.
Doug
Old Nov 29, 2005 | 02:22 PM
jlarmour's Avatar
That's why I bought this truck, wife took the ford away from me! I was just getting started on it but she liked it way to much!
Oh well the Dodge can make more power anyway!!!! Thanks!!!!
Old Nov 29, 2005 | 02:31 PM
jlarmour's Avatar
Ah-Oh,
Just started a war with father in law (2000 psd) he went and purchased superchip tuner (said it was 110 horse) and 4" exhaust, now I have to get this dodge done!!! Can't let him out do me!
Old Nov 29, 2005 | 02:37 PM
jlarmour's Avatar
Thank you, I'll get ahold of them.
Jer
grishfish
113
Mar 3, 2013 10:53 PM
GrumpyTX
Aug 3, 2007 02:40 PM
1just4don
Jun 17, 2007 01:59 PM
OOPS
Aug 28, 2004 07:15 PM
powerwagon440
Apr 19, 2003 07:19 AM
