need some o/f valve expertise
Old Jul 11, 2005 | 09:18 PM
bigair's Avatar
about two months ago I put a new overflow valve in because truck had a bad miss between 1000 and 1250 rpm. Needles to say after I put it in I noticed it started a lot faster and the miss was gone. Within a week or two the miss was back, but not all the time. It only seemed to come around once every couple days. Then more and more, now its there all the time. My question is, I read in a couple of threads that the free lenght of the spring is somewhere around .550. So I pulled mine out and it measures .760. Is this something I should be concerned with or am I just paranoid.
Old Jul 12, 2005 | 08:10 AM
bigair's Avatar
Nobody's even got and opinion.
Old Jul 12, 2005 | 12:29 PM
CarlJensen's Avatar
Length of spring should be .5 inch. If it has changed a reset of length will work for awhile but new is the way to go. Keep old for emergency use only. Once a spring loses it's strength it never comes back and will get weaker with time.
Old Jul 12, 2005 | 01:14 PM
bigair's Avatar
How do you reset a spring that is too long without cutting it. If I did that it wouldn't have a flat seat on teh bottom for the ball to rest on. I dont think I should have to cut it, I mean how does a spring that is always under tension get to be .200" longer then spec.
Old Jul 12, 2005 | 06:28 PM
infidel's Avatar
The .55 is for a valve set for 22-25psi
.76 is for a 25-28psi valve
Both pressures will work just fine.
I don't recommend that anyone plays with the spring unless you have a FP gauge to see what you've done.
Your problem sounds more like an injection pump delivery valve sticking. Try a heavy dose of fuel additive that cleans and lubes and see if that clears it up.
Old Jul 12, 2005 | 07:24 PM
JAFAW's Avatar
Or move the suspect dilivery valve and see if miss follows the delivery valve
jnall
Aug 12, 2011 12:42 PM
JDDODGE
Jul 19, 2011 03:03 PM
cowboy2526
30
Oct 13, 2008 11:54 PM
Derkaderka
May 17, 2007 10:38 AM
