Too much air
Old Jul 12, 2005 | 07:48 AM
Kroner's Avatar
Too much air
I let my friend who is a mechanic drive my truck because we have the same truck mods except he has the stock turbo. He said my temps rose faster because I have too much air goin in. (already checked for boost leak) My question is how do I add enough fuel to fix it and still keep it towable? Do I need injectors or dileveryvalves? Any help is appreciated
Adam
Old Jul 12, 2005 | 08:11 AM
heavyboostin's Avatar
I was under the impression that diesels used what air the needed, based on the fuel they injest, and thus no throttle body. Didnt know there was s such a thing as too much air....????
Although you can lug your motor to make it smoke because it has to much fuel, and not enough air...
Old Jul 12, 2005 | 08:15 AM
RowJ's Avatar
Agreed! Almost impossible to have too much air....at least as far as combustion is concerned.
I'm not real knowledgeable on 1st Gen trucks...but believe I have read elsewhere that no plate can cause your problems? I'm sure experts will chime in.
RJ
Old Jul 12, 2005 | 08:39 AM
BigBlue's Avatar
It's darn near impossible to have to much air on a diesel. To little air wold cause high egt's but to not much. If that were the case then everyone running an aftermarket intake on a completely stock truck would experience a rise in EGT's instead of a drop.
Old Jul 12, 2005 | 08:43 AM
CTD NUT's Avatar
Hmm....I take it he isn't a diesedl mechanic!! More fuel = more egt. You need more boost to cool the combustion down and to more thoroughly burn the fuel. It is, however, possible to overboost a turbo (overspeeding) which causes super-heated charge air and excessive drive pressures - this can also cause an egt rise. With your 14cm HX35, you should be able to efficiently boost to 38 - 40 psi - but no more. As RJ mentioned, running plateless makes for a much less than desirable tow vehicle as it makes it VERY difficult to control egt's. Keep your DV's - you already have 181's in the stock 215 pump and grind your own #100 plate or if don't want to grind your own, buy a #10, but the effort is quite worth it to grind the #100 (more top end). As for injectors, the most readily available are 370's but they won't do a darn thing to cool egt's down - they will do the opposite!! - but they will put one of these on your face as they will introduce a lot more fuel to the motor.
Old Jul 12, 2005 | 09:05 AM
Kroner's Avatar
He was thinking that I dont have enough fuel to spool the turbo? He is wanting to do my timing and maybe bumop my pump up 20 hp or so. Does this sound right?
Old Jul 12, 2005 | 09:27 AM
apwatson50's Avatar
do you put out black smoke off the bottom? do you have a boost gauge? stock fueling should be able to handle your turbo no problem.
Old Jul 12, 2005 | 09:38 AM
signature600's Avatar
Timing YES!! Put a plate in YES!! You have more than enough fuel to spool the turbo!
The only way you can have too much air in a diesel is when the turbo is moving more air than the engine can take, and it surges (the air flows backwards through the compressor). This is what I'm fighting now towing with my B1 at lower RPM (1500-1750).
This shouldn't be what you're fighting with that hybrid...is your friend running with no plate, too??
HTH,
Chris
Old Jul 12, 2005 | 10:54 AM
Kroner's Avatar
He has the plate ground down and all the way forward. My problem is that the temps rise higher and faster than with the stock 35. What would cause that? I thought a bigger turbo would lower temps.
Old Jul 12, 2005 | 11:31 AM
JDGnut's Avatar
What kind of boost pressures are you seeing??
Normally when you add a bigger turbo, or a bigger exhaust housing, you will see some increase in EGT's when you are just cruising.. basically no load... when you start spooling up the turbo, that's when you seen the benifits of the bigger housing or turbo... but you should not have any problems with a 14cm housing...
Bryan
Old Jul 12, 2005 | 11:45 AM
vssman's Avatar
How much boost are you running? If you overboost then, yes, your EGT's will actually rise due to superheating the air. I found my set up likes about 44 psi. Also running plateless will dump a lot of fuel in preboost and possibly may cause an EGT problem. Which brings another question... How hot is hot?
Old Jul 12, 2005 | 11:52 AM
Kroner's Avatar
I can hit 42 lbs of boost. Temps climb to 1200 pretty quick.
Old Jul 12, 2005 | 12:01 PM
apwatson50's Avatar
if your hitting that much boost you have too much fuel for the turbo. You need a bigger turbo! your just getting out of the map of the turbo. 1200 pre turbo is ok for a little while, does it climb higher or just settle down there?
Old Jul 12, 2005 | 12:02 PM
CTD NUT's Avatar
1200?!?! That is on the cool side for running plateless at WOT.....preturbo probe, right? Considering 1350 is your max sustainable temp and brief spikes past that are fine, it doesn't sound out of control. My 94 will peg the pyro BRIEFLY when running the 1/4 mile and runs fine.
Old Jul 12, 2005 | 02:03 PM
Kroner's Avatar
1200 after. With the stock 35 it would only go to 950. I checked for boost leaks tho and didnt find one. So now what? I guess I need to read more on here haha
