Need some help unhooking an edge COMP
Old Sep 2, 2004 | 05:46 PM
00turbo's Avatar
I'm getting ready to trade in my truck and I need to unhook my box but I didn't install it so i have no directions. Could someone please post some ?!
Old Sep 2, 2004 | 06:11 PM
Wolfeman's Avatar
Under the hood you will need to disconnect the wire to the injector pump. There will be a ground wire someplace that needs to be removed. No reconnection needed. Remove the MAP connector ( this is a tee connector ) and reconnect the original MAP connector. These wires need to be pulled back thru the firewall.
Under the dash the Comp will have a power connector, just disconnect. I think that is all there is to it.
Old Sep 2, 2004 | 07:05 PM
KatDiesel's Avatar
Don't forget to unplug the "data port" under the hood as well
Old Sep 2, 2004 | 10:40 PM
MLR1's Avatar
Here is a link to the Edge website you can download the instructions from this page. http://www.edgeproductsinc.com/instructions.html
Old Sep 3, 2004 | 06:53 AM
j-fox's Avatar
Don't forget to disconnect the batteries. if you don't it will set some codes.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
