need some help
Old Oct 2, 2007 | 08:03 PM
99globalwarmer's Avatar
need some help
today in traffic in my commute cummins 1999 auto the truck no longer locks, it has a valve body and goerend converter, what would cause the converter to not lock?
Old Oct 2, 2007 | 09:13 PM
come on ive searched but cant seem to find the problem
Old Oct 2, 2007 | 09:22 PM
Mike D's Avatar
Do you have a lockup switch?
Old Oct 2, 2007 | 09:28 PM
no not on this truck
Old Oct 2, 2007 | 09:31 PM
the ground seems to be fine, the connector going to the battery seems alright.
i checked all of the plugs on the trans and they are all tight and wires look fine.
Old Oct 2, 2007 | 09:34 PM
Mike D's Avatar
There is a relay in the power distribution box that could be bad.
Old Oct 2, 2007 | 09:35 PM
on the drivers side. i looked at it and i relly cant tell if its bad.
Old Oct 2, 2007 | 09:37 PM
the od light and switch works, it drops gears when coming off the freeway when i hit the switch but the converter wont lock.
Old Oct 2, 2007 | 10:02 PM
come on guys somebody has to have an idea what it could be.
Old Oct 2, 2007 | 10:08 PM
bama's Avatar
call dave,,,,,,,could be a solenoid,,,,could be a sticky brake light switch.........bama
Old Oct 3, 2007 | 08:53 PM
update thanks guys , a good old trouble code popped up today thank god. i think this is the only time ive been happy to see one. anyways it was a p1740 which is the od solenoid so thanks for the help.
bsj04
Sep 20, 2007 08:09 AM
Mini_Donkeys
Apr 19, 2007 12:21 PM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
JKM
Mar 4, 2005 03:33 PM
