Need HELP INSTALLING Pyro!!!
Old Oct 30, 2003 | 05:28 PM
phox_mulder's Avatar
Re:Need HELP INSTALLING Pyro!!!
Hundreds, nay thousands, of folk have done the pyro with the grease/shopvac/magnet method and didn't suffer a turbo meltdown.
Just get everything with the magnet, then when you're sure there aren't any chunks left, fish around with the magnet one more time, just to be sure.
phox
Old Oct 30, 2003 | 06:27 PM
VinDiesel's Avatar
[quote author=GreyBoy link=board=7;threadid=21644;start=0#msg203646 date=1067544496]
Then, should I let it idle a bit???
[/quote]
Yes. That's what I did. It's not an original idea- I was worried about shavings at first, but many on this forum eased my mind. When first started, at idle, the turbo isn't even turning yet. The puffs of exhaust can just blow any filings right through. I even started the engine once briefly with the new hole open (another avenue for something to get out).
Old Oct 30, 2003 | 08:36 PM
dukeboys's Avatar
Its probably a piece of mind thing. I spent a little more time (maybe 1 extra hour) and about $5.00 for a new exhaust gasket. But I KNEW I wouldnt have a problem. Im not saying Im right, it just works for me.
Old Oct 31, 2003 | 05:07 PM
GreyBoy's Avatar
Well, I finally got it installed last nite. Im having trouble keeping the a-pillar from falling off... using duck tape now, but gonna put ina sheet metal screw when I get the chance.... but atleast I can keep an eye on the EGTs!!!
I went the unconventual way and didnt unbolt anything. I spend a good hour or so with the magnet and then let it idle for 15-20 mins before driving it.
Im running between 650-850* normal driving and I peak at 1150* at WOT. Does that sound bout right with the stock plate slide all the way forward???
BTW I havent done the tranny guage yet, but I did do the boost and it peaks at almost 21 psi.
Thanks,
Sam
Old Oct 31, 2003 | 11:19 PM
VinDiesel's Avatar
[quote author=GreyBoy link=board=7;threadid=21644;start=15#msg204171 date=1067641622]
Im running between 650-850* normal driving and I peak at 1150* at WOT. Does that sound bout right with the stock plate slide all the way forward???[/quote]
Yes. My guess is if you were to stay "in it" long enough, or pull a heavy load or grade, you'd see it go higher. Just don't stay at 1350* for more than a few seconds. Now you can also watch the ex. temp. for cool-down purposes.
Old Nov 1, 2003 | 03:47 AM
GreyBoy's Avatar
Yeah, I noticed that as soon as I take the ol right foot out, the temps drop a good 2-300* same as when the turbo kicks in.
Sam
capt.Ron
Oct 8, 2004 12:33 PM
cLAYH
Aug 27, 2003 01:50 AM
ramguy
Jul 2, 2003 02:50 PM
Gene007
Jun 22, 2003 11:32 AM
shortfieldbreak
May 23, 2003 01:11 PM
