Need advice on which guages.
96 Dodge 3500 dually turbo diesel
I like the z series autometer. But im not sure which to get.
Mechanical boost 0-60 psi boost only
Or 0-30 boost and 0-30 vac
As far as fuel pressure do I get a 0-15 psi or 0-100 psi ?
Appreciate your replies.
Fuel pressure is probably the last one I'd get. Definately get a 60psi boost (I started with a 35 and that's now in the basement
) and get a pyrometer to keep an eye on EGTs. Next popular one for trucks with automatics is tranny temp gauge. 12v's don't have the same lift pump problems that 24v's have.
imcumin,
Pyro, boost 0-60 and fuel 0-30, if you have an auto trans get that instead of the fuel pressure or add it as well in a steering column mount by itself. Give us a clal if you want we have all the Auto Meter, DiPricol and Isspro guages as well as the mounts, paints, wiring harnesses etc to make the install as easy as possible for you.
Mark @ DPPI
Mark @ DPPI
Originally Posted by Mark Craig
imcumin,
Mark @ DPPI
Mark @ DPPI
Tx
imcumin,
Mark @ DPPI
Mark @ DPPI
At night it looks just like the stock guages...
Full kit ran me $309.00 lot cheaper that Autometers... Pyro & Fuel Pressure guages are high priced in Autometers... But very good quality!
Ok so on a 12V if you loose fuel pressure what happens? It doesn't kill the injection pump like it will on a 24V although it may run weak. Most won't even loose prime. I find it hard enough to keep my eyes on the road when the skinny peddle is on the floor let alone look at EGT, boost, tranny temp, fuel pressure, speed, tach....
The first time I try to look at all of the needles long enough to actually read them, I'll be greasy side up in a heatbeat.
Just my $0.02
Just my $0.02
I guess my last post was a little strong - I really didn't mean it that way.
Anyway, for a 24V I'd get a fuel pressure gauge first (even on a stock truck). Next an EGT, boost, tranny temp (especially if you tow).
Bradleysram
19
May 12, 2009 08:36 AM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
BoatRick
Nov 14, 2007 10:14 PM
Lomarker
16
Oct 22, 2006 06:54 AM
I recently found out that this truck (my inlaws) is actually a 98 - 24 valve turbo a/t cummins dually and not a 12v.
