Is My Ksb1-2 Junk?
Old Oct 25, 2004 | 02:32 PM
DynamicalyUnstable's Avatar
Is My Ksb1-2 Junk?
Ok, so I got the new turbo installed and I'm it's not all I thought it would be. It's a non wastegated one and I was told to expect 48-50lbs of boost. I haven't seen it get over 40. My stock one was getting a solid 33-36lbs and cooling just as well. I thought it might be because I hadn't put enough of a load on it but yesterday I towed around 7K up some decent grades and still never saw over 40lbs. Also, it has a very weird flutter sound when I am holding steady throttle pushing around 25lbs of boost. It almost sounds like the turbo bark flutter. Is that normal for this turbo?
Old Oct 25, 2004 | 04:33 PM
RowJ's Avatar
Somethings definately not right! Our set ups are very similar and when I had a KSB1-2 I got 48-50 at full power. No idea on the flutter either? Had a boot come loose once and could not pull more than 35 psi...worth a double check?
Definitely sounds like some kind of an air leak!
Another thought...have you done any break in? All B-1's come with VERY heavy breakin oil. I kept it under 20 psi for 1st 200 miles so I don't know what would happen if you tried fighting the heavy oil? Hard to believe that would be a problem after a few miles.
How's your spoolup?
RJ
04ctd
Mar 11, 2008 08:59 AM
HOHN
71
Oct 20, 2004 12:57 PM
DynamicalyUnstable
Jun 17, 2004 01:49 PM
Cowhand
May 23, 2004 01:36 AM
Sarge1124
0
Aug 23, 2003 12:20 AM
