Towing Power
Old Oct 24, 2004 | 10:15 AM
K2Cummins's Avatar
Towing Power
My farrier wants a little more power for towing. He has an 02 6spd w/gauges and 4" exhaust, stock everything else. I told him that an EZ would be perfect for his needs but then I found a Quadzilla 70hp box brand new for $325. Should he go with the proven EZ or are the Quadzilla boxes ok?
Thanks
Old Oct 25, 2004 | 12:41 PM
Diesel Dave's Avatar
I don't know anything about the Quadzilla boxes, but I am very happy with my EZ for towing.
Old Oct 25, 2004 | 01:12 PM
RustyJC's Avatar
Since he has the Cummins HO (ETH), I would suggest the Diesel Dynamics True Torque Power Module (TTPM) in lieu of the Edge EZ. The TTPM is an EZ with Diesel Dynamics specific programming and is not as aggressive with timing advance as the EZ - a benefit to the HO engine with its higher compression ratio. My personal opinion (despite the fact that I bought the EZ soon after I took delivery of my truck) is that the EZ is a little aggressive regarding timing for heavy towing with the HO.
JM2CW
Rusty
Old Oct 25, 2004 | 02:50 PM
HOHN's Avatar
JM2CW
Rusty
Agreed. I don't tow so I don't worry about the excess timing. But when I DID lay into a load with the HO, the engine acted like the timing advance (edit: of the EZ)was excessive, giving a thumping sound when it had to work hard....
Justin
Old Oct 25, 2004 | 04:46 PM
Car_nut57's Avatar
An Edge EZ, Banks diesel tuner or other like box should do well for towing provided he has the extra air flow such as a Scotty-II and Turbo Air Guide (TAG). Guages should also be on the list if he doesn't have them now.
Old Oct 25, 2004 | 06:46 PM
Rattletrap1's Avatar
Most would say that injectors will wake up the ETH better than a box. But then it's not as simple to install. Price can be abot the same or on up the ladder.
Some Mach 1's or 1.5's would be my call. From what Scotty says...the ScottyII won't do much for you at that power level. Neet stuff, but...
edonald849
Feb 22, 2009 04:44 PM
Trusty Steed
Feb 24, 2004 07:11 AM
cscobb1
Aug 10, 2003 10:22 PM
awmasparky
Jul 15, 2003 02:19 PM
tlampman
Dec 23, 2002 11:29 AM
