Multi-Hole injectors
Old Oct 8, 2002 | 09:28 PM
  #31
Extreme Diesel's Avatar
Re:Multi-Hole injectors
Yes, only one lil turbo. What pump are you running?
Old Oct 9, 2002 | 04:23 PM
  #32
J.R. Adkins's Avatar
913
Old Oct 9, 2002 | 05:22 PM
  #33
and you CAN'T get enough fuel out of it? ??? What rack stop cap do you have?
Old Oct 9, 2002 | 05:39 PM
  #34
TxDieselKid's Avatar
Don, I love ya but.....
I hear Piers is working on something simular as well. As I see it the more the marrier!!!
CC,
I think JR is pulling your leg, remember he has over 500hp. But there always is the P-8100...
Andrew
Old Oct 9, 2002 | 07:04 PM
  #35
Sled Puller's Avatar
[quote author=Don M link=board=7;threadid=5624;start=0#49540 date=1034024963]<br>Keith,<br><br>I have only had one failure myself. A collegue has had one as well. His chewed up some internals pretty bad. Engine required teardown. I have the problem solved with a modification to the nozzles and with the ones I am having manufactured the problem is not even a remote possibility.<br><br>Don~<br><br>[/quote]<br><br>AS I have said in the past I would like to break 600 with stock 370's. But that picture, and the 70hp gain has me reconsidering!!!(greed)<br>As always, I am concerned with life span. The tips have me nervous.<br><br>&quot;Not even a remote possibility&quot; sounds good, and is what I want to hear, but what proof do you have that they are that indestructable?<br>Gene<br>
Old Oct 9, 2002 | 09:46 PM
  #36
Don M's Avatar
DTR Advertiser
Everyones concern on broken tips is well warranted. After I experienced the problem I went to work to deal with the trouble. I have identified several ways to deal with it since May this year. The process I use actually increases the long term wearability over 450%. The material is stronger and tougher than it was from Bosch and has a structural integrity higher than what you got from the factory. There are three seperate processes to get them ready. <br><br>With the nozzles I had manufactured the problem is dealt with through a new design and a differing material used to construct them.<br><br>Part of the delay in getting these nozzles ready sooner was from having to deal with the tip breakage. I felt the failure rate of 2 out of 150 nozzles was very high. The tractor pullers deal with broken tips more than many folks know, but they use rather large holes in their nozzles. Not even additional holes in most cases. Just modified nozzles that have very large holes. Either way, the problem was/is real and just punching holes and running injectors can cause the user some heartburn later. <br><br>Don~<br>
Old Oct 10, 2002 | 08:36 AM
  #37
fj40charles's Avatar
Don,<br><br>Keep up the great work! We're eagerly waiting to see the dyno results...<br><br>Charles
Old Oct 10, 2002 | 08:19 PM
  #38
gitchesum's Avatar
I think Don needs someone to test these injectors in this coastal climate we got down here in Houston. <br><br>Good job Don. Lemme know if I can help.
GO 4LO
Nov 1, 2005 02:59 PM
Dave88LX
Sep 13, 2005 10:45 AM
Buzz
Jan 7, 2003 01:25 PM
