more smarty ?'s
Old Mar 13, 2006 | 10:09 AM
Twodiesels's Avatar
more smarty ?'s
I have a hesitation when i step on the throttle. Just replaced the vp and fuel pressure is at 17. If i reset the apps, do i need to remove the smarty program? Is it ok to disconnect neg. Battery cables with the smarty installed?
i have noticed on my truck with the smarty and box off it has a flat spot around 25oo rpm. Does not with the comp on. Any ideas about this.
Thanks
Dan
Old Mar 13, 2006 | 10:21 AM
HOHN's Avatar
You can reset APPS with smarty, no problem. Same for battery terminal.
I have no flat spots with Smarty, so I'm guessing it's not the Smarty. Probably the Comp-- even when it's off.
Old Mar 13, 2006 | 03:47 PM
RowJ's Avatar
People with stock injectors are reporting a "flat spot" after about 2" of throttle... but no one with larger injectors has seen this! What "70 hp injectors" do you have?
Comments here (including Marco).
https://www.dieseltruckresource.com/...ad.php?t=95303
RJ
Old Mar 13, 2006 | 05:15 PM
Twodiesels's Avatar
They were rebuilt by scheid rated at 70rwhp. Got them used and have been great.
Old Mar 13, 2006 | 07:27 PM
MKELLY's Avatar
RJ at what setting does this occur or is across the board. I've been running mine on the 5 setting and it keeps pulling till I let off. My buddy just test drove mine tonight and said it blew his Banks Six-Gun tuner away.
Old Mar 14, 2006 | 07:16 AM
RowJ's Avatar
Originally Posted by MKELLY
RJ at what setting does this occur or is it across the board.....
If your asking about the flat spot... I don't expirience it with my Mach 4's.... and all I know is what others say in the post I refered to above.
Can't answer your question.
RJ
stock03
34
Apr 21, 2011 07:40 AM
Ghost Ram
Feb 2, 2008 07:50 AM
bnold
39
Jun 4, 2006 08:21 AM
j
Dec 21, 2003 10:26 AM
Commatoze
Nov 20, 2003 06:06 PM
