Which Mod?
Old Apr 23, 2003 | 11:50 AM
Jim in Co's Avatar
Which Mod?
Hello all, I have an 01 4x4 3500, 36000 miles, stock dodge (3.55's). Lets say I have no more than a thousand dollars to spend. Which engine modification should I start with to get more power for towing, I have a 2500 lb slide in camper and tow @ 2000 lbs of atv's and stuff. I do not want to void any engine warranties. I am not a major gear head so I prefer easily installed equipment. So what should I start with. Lets take for granted I am going to install the bare minimum of a pyrometer. Where to from here?<br>Thanks<br>Jim in Co.
Old Apr 23, 2003 | 12:03 PM
rharveysr's Avatar
Re:Which Mod?
Hi Jim,<br><br>Here is the steps to start down the path to the dark side..oh I mean the power side..lol<br> <br> A-Pillar full of gauges...ie..pyro,boost,fuel pressure<br> Edge EZ<br><br> That will get you started and just about a grand..<br><br> Rick
Old Apr 23, 2003 | 12:26 PM
hellotbone's Avatar
Re:Which Mod?
Alot depends on you plans in the future if you plan on just a simple towing upgrade an edge EZ and 275 injectors with a full compliment of boost/pyro/fp gagues.
Old Apr 23, 2003 | 12:40 PM
BFC's Avatar
BFC
Re:Which Mod?
Gauges, EZ, air filter. Would be a good start and stay with in your budget and the easy install.<br><br>Glenn
Old Apr 23, 2003 | 04:21 PM
pro puller's Avatar
Re:Which Mod?
id go with the mods the other guys talked about except id go with the edge comp &amp; leave the pump wire unhooked instead of the ez.lets face it guys as soon as he gets a taste of power hes gunna want more.then well talk about trany mods &amp; all the other fun stuff that comes with the horsepower bug.have fun..kurt.
Old Apr 23, 2003 | 07:21 PM
geer's Avatar
Re:Which Mod?
I was in the same boat. I went ahead and got the comp and ran with the wire unhooked. It was a huge difference so much that I tapped the wire after a week. That is when I found out what they mean by the dark side. Get the comp.
Old Apr 23, 2003 | 09:43 PM
HC's Avatar
HC
Re:Which Mod?
I believe the advice the others gave you for how to increase power is on target, BUT, I think they missed one line in your original post: You said, &quot;I do not want to void any engine warranties.&quot;<br><br>You can't have it both ways, except by commiting fraud. The warranty is a contract between the manufacturer (Dodge), and the customer (you), and one of the conditions of that contract is that you don't step up the power by performing unapproved, power-enhancing modifications. Sometimes you can &quot;fool&quot; the dealer, but that's not the same thing as saying you can legally vary from your end of the contract while expecting Dodge to hold up their end. Some dealers may allow minor enhancements, like maybe installing 275 RV injectors, but that is something you need to discuss openly with your dealer to see where he stands. Dodge's official position would be &quot;no&quot;. (There may be some minor exceptions - certain models can get a dealer &quot;reflash&quot; of the computer for a little power gain, but the Dodge-approved reflashes are overpriced and don't hop up the power nearly as much as the aftermarket mods.)<br><br>If you have a manual, get an exhaust brake instead - installed by your dealer, it won't void your warranty.<br><br>Otherwise, decide which you want more - the warranty or the additional power. Some folks compromise - pick a mileage you feel comfortable with like 20k or 50k, then do the mods and don't worry about warranty past that date.
Old Apr 24, 2003 | 02:38 PM
BarryG's Avatar
Re:Which Mod?
If you have a stick I think dodge makes the torquis maximus ecm I dont think it will void your warranty. Course it is twice as expensive as comparable boxes and doesn't give you as much. At least I think I saw that box in dodge add and if I recall it was about 900.00
Old Apr 24, 2003 | 04:54 PM
Jim in Co's Avatar
Re:Which Mod?
Thanks for all the advice. I think I am going to go with a higher air flow air filter, edge ez and some gages on a pillar for now. I think next I will probably lose the resonator and get a 4 inch exhaust. Thanks again.<br>Jim in Co
Bradleysram
19
May 12, 2009 08:36 AM
jmccart
Dec 19, 2007 12:49 AM
jamesbfishin
Jul 7, 2007 08:25 PM
wap
14
Apr 23, 2007 06:46 PM
RAMV
Jul 14, 2004 12:08 PM
