Mileage Limit before starting to bomb?
Old Feb 22, 2003 | 09:55 AM
GO 4LO's Avatar
Is there any specific mileage limit before starting to bomb a Cummins? I know they last forever, but would it be wise to install a twin setup on a 200k+ mile truck, for example? Thanks.<br>Chris
Old Feb 22, 2003 | 10:10 AM
John_P's Avatar
Re:Mileage Limit before starting to bomb?
GO4LO:<br><br>I would not be too concerned about the miles on a <br>Dodge CTD with reference to when you begin <br>BOMBING one.<br><br>As long as the truck has had good maintenance<br>(oil changes, valve adjustments etc.) and the<br>truck is not using oil I really don't think you have<br>to worry.<br><br>One point about twin turbos..............<br>If you do this be sure you set-up the twins with<br>some type of wastegate as the high drive pressures<br>and boost will definitely blow the headgasket!<br><br>--------<br>John_P<br><br>
Old Feb 22, 2003 | 10:17 AM
GO 4LO's Avatar
Thanks for the advice, John. I'm currently trying to make up my mind between a new '03 (which I wouldn't bomb much for warranty's sake) and a used '97/'98, which would get a full twin setup. Enterprise Engine is about 2.5 hours from me, and I'd be having them do all the work on the twins, if I go that route. <br>Chris
Old Feb 22, 2003 | 06:25 PM
John_P's Avatar
GO4LO:<br><br>You are welcome! Let me know if there is anything<br>else I can do for you and good luck in whatever you<br>decide to do!<br><br>--------<br>John_P
coreydr2003
Feb 11, 2008 07:21 PM
jjj_85
Nov 19, 2006 06:07 PM
flyfsh70
May 8, 2005 10:33 PM
YinYaker
Nov 10, 2003 12:28 PM
