melted pistons?
Old May 14, 2007 | 08:45 PM
  #31
XLR8R's Avatar
Yes, they can be honed w/o removing the engine, but if the cylinder walls are scored badly you'll likely need to bore it and install an oversize piston - otherwise it's an acceptable service procedure to sleeve the cylinder and keep the original piston if it's undamaged.
FSM recommends max bore of .040" IIRC
Old May 14, 2007 | 09:53 PM
  #32
iforge03's Avatar
that doesnt sound too bad. i talked to a mechanic from the local dealership and he said the master mechanic there is willing to do the work on the side in trade for a side of beef. so it may not cost me as much as i thought it would. im going to take it to him so we can compression check it tomorrow. i wouldnt mind doing the work myself, but it would probably cost me as much to get all the right tools as it would cost me to have it done.
Old May 15, 2007 | 06:50 PM
  #33
dogdog784's Avatar
I bought the compression tool for $150 and it cost $300 for fire rings and head gasket and $100 for new rings. The really is no special tools other than the compression tester. Its fairly easy to do.
Old May 15, 2007 | 07:44 PM
  #34
iforge03's Avatar
did you have to do any machining to the block or just replace the rings and put it back together. i am planning on taking the head in to get it o-ringed and put studs in also.
Old May 16, 2007 | 04:55 PM
  #35
iforge03's Avatar
the mechanic came over with some pretty nifty diagnostic tools. at first it wouldnt start for him, we cracked a fuel line, bled it and it fired right up. it was the first time it hadnt started for me. the conclusion was bad vp aerating the fuel. used his nifty tool and shut each injector off one at a time and it seems like the jammers arent working to uniformly. going to order some f1 injectors and swap out vp
Old May 16, 2007 | 07:43 PM
  #36
dogdog784's Avatar
The jammer injectors should have a lifetime warranty send them back and sell the new ones they give you.
Old May 16, 2007 | 10:34 PM
  #37
HOHN's Avatar
Originally Posted by dodgeguy71
The Dodge dealer can't actually test the injection pump. A local Cummins dealer near the house here can bench test the VP and check it out. They told me that when my Vp took a dump. They are bosch certified to rebuild the Vp's. They told me to pop it off and bring it in but it was to late, the dealer had their shotgun out shooting parts at it.....not the vp though, had to go back for that one.
I agree with tate. On my 1300 mile journey to Georgia and back I was getting dead pedal and not once did the CEL come on.When I got back and after the dealer put in the lift pump, the next day the CEL did not come on when I got dead pedal again. Check for codes anyhow, I just cycled the key and it flashed the death code for me
I had intermittent dead pedal issues and I thought is was the (t)rusty APPS.
Turns out it was a bad ECM! Good thing, too-- I lost a VP at 40K and this was happening around 50K-- I'd have done something irrational if a VP only lasted my 10K with an untapped wire!!
Old May 16, 2007 | 10:36 PM
  #38
HOHN's Avatar
What't the spec for balancing? That lone oversized piston is going to be heavier than the others, and balance could be an issue...
Just a thought..
Old May 17, 2007 | 12:02 AM
  #39
iforge03's Avatar
i just went through the ecm thing a few months ago. it took three weeks for me to recieve my ecm, 10 minutes to swap it out in the dark. i didnt have any dead pedal at all but my fuel is cavitating and the guy that is helping me said everytime he has seen that, the pump was bad. he is suggesting new vp and injectors. i just dont see how my injectors could go from running so smooth, to so badly all of a sudden. i think ill just swap out the vp and see what happens
Old May 17, 2007 | 06:27 AM
  #40
blackdiesel's Avatar
Registered
I say you right about the injectors (very rarly go bad). Make you wonder about the guy helping you.
Old May 17, 2007 | 06:35 PM
  #41
iforge03's Avatar
he kept telling me i ought to put in some rv injectors because they are a great power upgrade and he can get them for the bargain price of 115.00 a piece. i can almost get a set of f1 injectors for that price. i think ill swap out my vp and see where it goes from there
Old May 17, 2007 | 10:07 PM
  #42
Registered
As you know, any one can get a SET of rv's for $300 or less
Old May 27, 2007 | 01:44 AM
  #43
iforge03's Avatar
it turns out that this guy really knows his stuff. he put a new (oem reman) vp on for me, for 1125 out the door. on the old pump, the key was almost sheared off and it clicks when you turn the shaft. truck started right up but #1 and 5 injectors are just dumping fuel into cylinder. most likely that vp blew shrapenel into injectors. the injectors he told me about werent rv 275's. he can get factory bosch injectors for different applications that can add big horsepower. he just has to find the vin numbers for the right motor configuration to get me the right size injector. but for right now i am going to swap in a set of stock injectors he is giving me. i think i will order some f1 injectors in the near future. he told me that a 2001 was just brought into the shop with a broken rod and the estimate came in around 14000.00 for repair!
Old May 27, 2007 | 11:17 AM
  #44
chuxtruk's Avatar
$14000.00 for repair...
Won't $6000 get you a re-man long block? Add in expensive labor and you should be well shy of that BIG number above.
You should be able to RE-MOTOR BRAND NEW for $14000....and I would think installed. God, that's a LOT of money!!!!
I think it would be cheaper to unscrew the radiator cap and drive a new(er) rig under it, screw the lid back on tight and continue driving!!
erniew
Sep 6, 2009 12:43 AM
RollinCoalSmoke
May 29, 2009 09:20 PM
skynyrd
Jan 10, 2008 06:41 AM
blownsmoke2
52
May 24, 2007 10:25 PM
ddestruel
May 10, 2005 12:17 AM
