Max boost pressure
Old May 13, 2004 | 09:44 PM
OldSmokey's Avatar
Max boost pressure
What is the max boost pressure that can be run safely with stock head gaskets, or any thing else that would fail due to high boost pressure.
Old May 13, 2004 | 09:47 PM
phox_mulder's Avatar
Head gasket can take up to 50 I think.
Stock turbo on the other hand, might be able to handle 40 before turning into shrapnel (might),
but just prior to grenading it, you're heating the air, which you don't want to do.
phox
Old May 15, 2004 | 02:54 AM
BigBlue's Avatar
I've heard of stock gaskets going to 60 psi with studs and a clean surface. Safely is 50 though. Your stock turbo is good for about 35 psi and that's it. After that, your just heating up the air and killing your power.
Old May 15, 2004 | 09:21 AM
BPonci's Avatar
I ran 55 to 60 psi the stock gasket never blew.I pulled the head to install a stage 2 pdr head and the stock gasket looked great.I now run a oringed head and im up to70 psi with no ill effects..........P.s. in ran boost pressures of 55 to 60 for about a year.
Old May 15, 2004 | 10:59 AM
csutton7's Avatar
one key is to make sure the truck/engine is good and warm before hammering the throttle---head gaskets have been known to blow at lower boost pressures on a cold engine---I'd think most guys would say 60 would be the max(scary range)--50-55 should be no prob as long as she's warm--chris
DF5152
May 29, 2013 08:57 PM
Tingram
Mar 9, 2009 11:26 PM
GTSDave
Jul 8, 2005 09:06 AM
belfert
Sep 9, 2004 03:23 PM
Zino
Aug 15, 2003 10:14 PM
