map sensor on switch
Old Mar 12, 2006 | 10:07 PM
jeeptjstud's Avatar
anybody ever tried this? I want put my MAP sensor with my comp on a switch so I can turn it on or off. Anybody tried this?
Old Mar 12, 2006 | 10:18 PM
displacedtexan's Avatar
Never tried it, but shouldn't be that hard at all. The hardest part would be fishing the wires throught the fire wall. Should be able to just cut one of the wires, splice two leads to it, pull them into the cab, and mount the switch where ever you want.
Old Mar 13, 2006 | 06:50 AM
Bart Timothy's Avatar
I'll bite. Why?
Old Mar 13, 2006 | 06:56 AM
Originally Posted by Bart Timothy
I'll bite. Why?
Unplugging it with a Comp type box gives you LOTS-O-SMOKE but is not real good for the engine.
Old Mar 13, 2006 | 07:59 AM
Dusty Ratcliff's Avatar
DT, why do you say it's not good for the engine??? I've never seen any ill effects from it, & seems to me it's about the same as adjusting the starwheel on the 12-v motors???? just curious??? not flaming, I was just wondering if you knew of problems that I hadn't heard about yet, thanks, Dusty
Old Mar 13, 2006 | 08:13 AM
SuperDave4x4's Avatar
I've thought about doing this, but I still haven't figured out if you are going to need 2 switches or just one. There are two wires that go to the map sensor and when you unplug the map sensor you are unplugging both of the wires. I guess the only way to find out is to cut one of the wires and if that wire doesnt work, hook it back up and cut the other one and if that doesn't work then you'll that you have to have both wires on a switch.
Old Mar 13, 2006 | 01:41 PM
SjLingenfelter's Avatar
I thought there were 4 wires on the map sensor? I too have thought about this but im afraid of throwing a code by just cutting one wire and puttin it on a switch.
Old Mar 13, 2006 | 05:04 PM
jeeptjstud's Avatar
theres a guy on www.cumminsforum.com that just cut a wire near the comp and wired it to one switch. I am trying to get the info on it. I will post it if I can find out how he did it.
Old Mar 13, 2006 | 08:34 PM
Clunk's Avatar
Question
What's the advantage of washing down the cylinder walls, no power and smoking like tire dump fire?
Old Mar 13, 2006 | 09:24 PM
I believe I read that it was not to good to run with the map unplugged. But I cannot say why. I may be wrong on this one. I think I was confused, and thinking of something else.
Or maybe just that it is bad to run with the MAP unplugged on a stock engine.
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
