Makin Oil???
Old Apr 2, 2008 | 06:40 AM
Redliner's Avatar
Makin Oil???
So I checked my oil yesterday and its about 2 qts over. I havent changed anything in the last 10000 miles, so what could be going on???? If I could just make fuel that easy man would I really love my truck.....
Old Apr 2, 2008 | 06:42 AM
meangreen96's Avatar
Are you sure there's no fuel or water in that oil?
Old Apr 2, 2008 | 06:54 AM
Redliner's Avatar
There is 3000 miles on the oil change. I check it everytime I fill up and has never gained oil or lost oil sense Ive owned it. Its black but im fightin the flu so I cant smell anything, as far as fuel. The radiator has not dropped at all so im guessin that its not water.....
Old Apr 2, 2008 | 07:09 AM
Diesel_Dan's Avatar
I would think fuel, both the lift pump and the IP can do it. seals go bad and just dumps fuel into the case. One problem with that, diesel thins oil.
Old Apr 2, 2008 | 07:34 AM
patdaly's Avatar
Could be Injectors, IP, not too much else I can think of on a VP truck.
Old Apr 2, 2008 | 07:47 AM
Diesel_Dan's Avatar
oops I missed that is a VP truck no worry about lift pump leaking
Old Apr 2, 2008 | 07:49 AM
nickg's Avatar
Could be the injector O-rings leaking ,actually more likely than not
Old Apr 2, 2008 | 08:27 AM
Redliner's Avatar
But why all of a sudden..... The injectors have been in for about 20000 miles, only thing that I changed sense the injectors was a new turbo.....
Old Apr 2, 2008 | 05:29 PM
Big Blue24's Avatar
Redliner, I just went through what you are going through right now. My injectors have not been touched for a year so about 25,000 miles but it started making oil and fast! Turned out to be #3 injector. I just removed the valve cover, started her up, and looked for bubbles around the injectors. It is almost impossible to get a good look at #5 and #6 but after changing the oring on #3 bubbly injector, my problem stopped.
All that I can figure is the cold weather makes for colder than normal starts when the o-rings aren't warm and pliable to help seal in the overflow fuel.
Old Apr 2, 2008 | 05:33 PM
Big Blue24's Avatar
By the way, I put this off for a week and just changed my oil because idling oil pressure was low and in a week It made two quarts. I finally set aside enough time on a Saturday and it only took 1 hr because it was just one injector so I didn't remove much to get at the o-ring.
I hear that Bosch, and or cummins can supply you with some tracer dye to put in the fuel filter canister that shows up real well with a black light to find even trace leakage.
Old Apr 2, 2008 | 09:11 PM
Redliner's Avatar
Thanks guys Gonna try that this weekend.... Ill keep you posted....
blacksmoke
Oct 30, 2013 12:43 AM
DirtEater
32
Aug 2, 2010 05:49 PM
Push Rod
Aug 19, 2004 05:50 PM
Stamey
Mar 9, 2004 08:57 PM
j
Nov 10, 2002 10:40 AM
