Make hole without Scotty II?
Old Jan 2, 2003 | 02:19 PM
atc250r's Avatar
I just put a K&N oval cone filter (RF-1024) on the end of the stock turbo to airfilter hose since $$ didn't permit a Scotty yet. The filter sits right where the airbox used to be. Is there any benefit to cutting the hole now or should I wait until I can afford the Scotty? If there is a benefit could someone direct me to a site where I can learn where to make the hole? I already know it is made with a 4.5" hole saw. BTW if anyone wants a budget set up like this, all I bought besides the filter for $50 was a $2 PVC coupler and a $2 metal band from the local hardware store. It seems to work well and it sounds like the turbo is gonna jump out from under the hood and kick some a$$ on its own. I haven't turned on the stereo since I put it in this morning, AAHHHHHH the sweet sound of a spooled turbo!!
thanks.
John
Old Jan 2, 2003 | 02:44 PM
banshee's Avatar
Re:Make hole without Scotty II?
Oh yeah, it will help you out. Daniel (CMNS PWR) did this to his truck, and he said he noticed a difference with the hole cut. A scotty will only add to it.
Old Jan 2, 2003 | 05:02 PM
atc250r's Avatar
Thanks. Can someone please send me in the right direction as to info on where to cut it? I checked WildCatDiesel but had no luck on finding info on this mysterious hole that I need to make.<br><br>John<br><br>
Old Jan 2, 2003 | 06:57 PM
dodgeram's Avatar
http://www.scottyairsystems.com/
check out the install instructions
fold the insulation pad on the cowl wall out of the way. Then, drill the 4.5&quot; hole directly adjacent to the reinforced edge
before
after
close up
Old Jan 2, 2003 | 07:41 PM
drawson's Avatar
atc250r, From what I have seen drill the hole would do you much good because you would still be getting the hot under hood air. In fact I would guess that hardly any of the air from the hole would get into the filter. Also when not moving you would get alot of engine smell in the cab.<br><br>I would hold off until you got the CooOOoooOOOoooOOOOLest Air sucking system out there.<br>
Old Jan 2, 2003 | 09:56 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Hey Jack!<br><br>I've asked you once, now I'm beggin' you:<br><br>Please, please, PLEASE rig the censor so that if anyone spells COOL with more than 2 O's that the message be censored, and a big hand comes out and whacks the typist?<br><br>Thank you.<br><br>Rod
Old Jan 2, 2003 | 10:25 PM
Scotty's Avatar
Top's Younger Twin
[move][glow=blue, 5, 500]COOOOooOoOooOOOOooOOOooooL[/glow][/move]<br><br><br>All of a sudden I am knocked off my chair and wandering aimlessly...I feel like a sheep after being near Rod. Dazed and confused. <br><br><br>[move][glow=red, 8, 500]BAaaAAAaAaaAaA[/glow][/move]
Old Jan 2, 2003 | 11:18 PM
atc250r's Avatar
Drawson,<br><br> Are you suggesting that I have a smelly engine? I rinse it down whenever I wash the truck so I really find it hard to believe that it has a hygiene problem.<br><br>John<br><br>
Old Jan 2, 2003 | 11:22 PM
admin's Avatar
scotty=
Old Jan 2, 2003 | 11:26 PM
drawson's Avatar
No smellier than any Cummins.
[move]COoOoOOOoooOOOOooooOOOOOOoooooooL AIR [/move]
Just for you Push Rod
GO 4LO
Nov 1, 2005 02:59 PM
Dave88LX
Sep 13, 2005 10:45 AM
Forrest
Apr 7, 2004 11:42 AM
yrusoslow2
Sep 23, 2003 11:26 PM
